مشاهدة نتائج الإستطلاع: fredom
مجبر 0 0%
مخير 1 100.00%
حاحة تانية 0 0%
المصوتون: 1. أنت لم تصوت في هذا الإستطلاع
قديم 10-03-2011, 04:14 PM
corsair
افتراضي كل ما تريد معرفته عن الاليكتريك شوك اسعار وانواع
اولا النوع اللي لاقوه في امن الدولة
ده توأم النوكيا ال N73 بس هو في الحقيقة مش موبيل هو صاعق كهربائي
تم اكتشافه في امن الدولة واتضحلي بعد كدا انه بيتباع
سعره 24 دولار او 142 جنيه
مواصفاته
Supervoltage self-defensive flashlight cell phone stun gun-K95
Main parameters:
1. Output pulse voltage: 2000KV
2. strong illumination
3. Size: 2.5*5*11CM
4. stun gun and LED flashlight
This self-defensive Stun gun has several special functions such as high voltage electric shock and strong illumination. It is an ideal self defense device for law enforcement, security guards and civilians due to their extended reach and power.
Self-defensive Stun gun is made of ABS engineering plastic and alloy metal with a high voltage generator and a built-in nickel-cadmium rechargeable battery. It has an advanced electric pulse technology.
Usage and attention:
1.Push upward the right switch second gear to shock
2.Push upward the right switch first gear to illuminate
3.The quantity of electric may be not adequate enough after accomplished, so please check first before using.
4.This product is equipped with a built-in rechargeable battery and a built-in charger. Connect the tie line with the electric power to charge.
5.The charge time should be 3- 5 hours, please pay attention to end the charging time. During charging-up it can`t be used.
6.Memory function and local action are specialized in rechargeable battery. After a long period of non-use, it should be checked and charged one more time before using.
7.The stun gun should not be stored in a humid environment and kept in super high/low temperature. It shouldn`t be sunned or rained.
8.In order to prolong the life span of usage, please avoid using electric shock function continually for 5 seconds or more.
9.DO NOT shock metal objects
10.DO NOT shock children, children, persons with heart disease and any vital part on human body.
ـــــــــــــــــــــــــ ـــــــــــــــــــــــــ ـــــــــــــــــــــــــ ـــــــــــــــــــــــــ ـــــــــــــــــ
النوع التانيده الميني
النوع ده ب 12 دولار او في حدود 120جنيه مصري
Main parameters: 1. Output pulse voltage: 2000KV 2. strong
illumination 3. Size: 10*2.5cm 4. stun
gun and LED flashlight This
self-defensive Stun
due to their extended reach and power. Self-defensive Stun
gunis
has an advanced electric pulse technology. Usage and attention:
1.Push upward the right switch second gear to shock 2.Push upward
the right switch first gear to illuminate 3.The quantity of
check first before using. 4.This product is equipped with a
tie line with the electric power to charge. 5.The charge time
time. During charging-up it can`t be used. 6.Memory function and
before using. 7.The stun
sunned or rained. 8.In order to prolong the life span of usage,
seconds or more. 9.DO NOT shock metal objects 10.DO NOT shock
on human body.
النوع التالت وده السوبر فولت
وده سعره 20 دولار او حوالي 125 جنيه
مواصفاته
Supervoltage self-defensive flashlight stun gun-800
Main parameters:
3. Size: 10*2.5cm
4. stun
7.The stun
وده النوع الرابع واشدهم في الشكل
والنوع ده تمنه 24 دولار او 142 جنيه مصري
ومواصفات الجهاز ده
Main parameters:
3. Size: 2.5*6*12cm
4. stun
Self-defensive Stun
7.The stun
النوع الخامس والاخير
وده سعره 27 دولار او 150 جنيه مصري
ومواصفات النوع ده
Main parameters:
1. Output pulse voltage: 2400KV
3. Size: 18.5*4cm
قديم 10-03-2011, 04:18 PM
الصورة الرمزية خالداعزالناس
من انا؟: مهندس/ خالد
التخصص العملى: مهندس اتصالات
هواياتي: التنزه - السفر
الموقع: القاهره
افتراضي رد: كل ما تريد معرفته عن الاليكتريك شوك اسعار وانواع
تسلم على الموضوع
وكعادتك دائما .... مواضيعك أكثر من ممتازه
قديم 10-03-2011, 04:19 PM
mesho70 mesho70 غير متواجد حالياً
من انا؟: ابو احمد وشهد
التخصص العملى: مهندس مساحة
الموقع: مصر
mesho70 has a reputation beyond reputemesho70 has a reputation beyond reputemesho70 has a reputation beyond reputemesho70 has a reputation beyond reputemesho70 has a reputation beyond reputemesho70 has a reputation beyond reputemesho70 has a reputation beyond reputemesho70 has a reputation beyond reputemesho70 has a reputation beyond reputemesho70 has a reputation beyond reputemesho70 has a reputation beyond repute
اية الحلاوة دى
قديم 10-03-2011, 04:21 PM
corsair
وديه كانت مفاجئتي ليكم وطبعا بتشتروه من عن طريق النت والشحن الدولي وده لينك للي عايز يشتريه
وفي انواع تانية كتيرة هتشوفوها علي اللينك ده
http://www.ioffer.com/selling/dvrcamera/Stun-Gun--29983
قديم 10-03-2011, 04:26 PM
SHERIF MARLBORO SHERIF MARLBORO غير متواجد حالياً
من انا؟: /طالب!/سائق
التخصص العملى: علوم الحاسب الالى و نظم المعلومات
هواياتي: الكمبيوتر التأمل حب الجمال
الموقع: اسكندرية
SHERIF MARLBORO has a reputation beyond reputeSHERIF MARLBORO has a reputation beyond reputeSHERIF MARLBORO has a reputation beyond reputeSHERIF MARLBORO has a reputation beyond reputeSHERIF MARLBORO has a reputation beyond reputeSHERIF MARLBORO has a reputation beyond reputeSHERIF MARLBORO has a reputation beyond reputeSHERIF MARLBORO has a reputation beyond reputeSHERIF MARLBORO has a reputation beyond reputeSHERIF MARLBORO has a reputation beyond reputeSHERIF MARLBORO has a reputation beyond repute
افتراضي رد: هيا دي الشرطة اللي عاوزينها
أنا للأمانة فرحان و لو فعلا هيعلوا كده أنا اللى هشوفه من الداخلية هديله علبة سجاير(لوبيدخن)و و هدية و ابتسامة
يارب انا فرحان علشان بتفرج عليهم كده عقبال مفرح تانى و هما بيعملوا الكلام ده
الحلم
27 مايو, لادن, ليبيا, أسامة, آسفون, موبينيل, مونتو, أضرار, المينا, المصري -اللي -علي- حق -ما, الثانوية العامة, الجامعة الامريكية, الحاضر, الغلطة, القسم . الاجباري, الكسوف, ابيدال-برشلونة-عنصرية-ابراهيم عيسى, ابويا بقي مراقب, ابوك\عربية, club aldo, تعليم قيادة السيارات, ثورة 25 يناير, بوروروم, تنس -رياضة-, تونس, بكاء, بكار, libya, سيارة مستعملة للبيع, سيارة-زرافة-برنامج, شعار المرور الجديدة لعام 2011, revolution, sory, tunise, علم -اجتماع, عضة, إندومى, ولع ولع حريقة ولع ولع حريقة, نتيجة 2011, نتيجة الثانوية العامة, نجيب, نصر-اكتوبر-القوات-المسلحة, كلمة
الساعة الآن 04:45 PM.
