قديم 04-10-2012, 05:37 PM
الصورة الرمزية ahmed_eng2001
افتراضي رد: حكايتـى......... مع الكارونة
شكرا لمرورك يا باشمهندس أحمد نورت الموضوع
كمال موجود فى ميدان الظاهر امام بنك بى ان بى باريبا وجنبه قهوة على ناصية الشارع وماأخدتش رقم تليفونه
سلامة أخصائى كوارين
عزبة شلبى من ناحية البحر
تليفونه :01222231011
لا شكر على واجب
الشكر ليك لنقل التجربة
نسيت اسالك ..... فين الراجل الى فى حدائق القبة ... مكانه فين ؟
قديم 05-10-2012, 06:08 PM
انذار Diagnosing Differential and Driveline Noises
[QUOTE=Hisham.Elgazzar;771 912]
شكر واجب وتحية تقدير وإحترام لإخوانى
أ\ مصطفى عاطف
أ\ أيمن الروبى
م\ عمرو السيسى
م\ محمد مرسى
وطبعا مش هنسى
كارز أدماير
م/ حمدى المخترع
We don't know which sounds worse—us singing show tunes in the shower or a howling differential. While there is no help for our singing, i can help you diagnose the sounds coming from a differential gone bad.
A clunk, whine, or howl can signal a worn-out pinion gear, bad bearings, or a faulty gear installation. Sometimes, the noise is not differential-related, but is caused by other driveline or axle components. The guide below will help you match up the noise you're hearing with the differential or axle component making it—or at least get you in the ballpark.
Noise: Howl while decelerating (gears previously quiet)
Cause: Loose pinion bearing preload
Noise: Howl with whir or rumble while accelerating at any speed (gears previously quiet)
Cause: Worn rear pinion bearing or worn gear set
Noise: Howl without whir or rumble while accelerating at any speed (gears previously quiet)
Cause: Worn gear set due to lack of lubrication or overloading
Noise: Howling while accelerating over a small speed range (gears previously quiet)
Noise: Howling after gear set installation
Cause: Faulty gears or improper installation
Noise: Low-pitch rumble at all speeds over 20 miles per hour
Cause: Worn carrier bearings
Noise: Whirring during acceleration/deceleration at about 10 miles per hour
Cause: Worn pinion bearings
Noise: Banging or clunking while making a turn, backing up, or rapid deceleration (like on a freeway off-ramp). Noise gets worse in warmer weather
Cause: Posi chatter due to improper lubrication; worn clutches or spider gears; improper assembly
Noise: Banging, crunching, or popping while making a turn. Noise not affected by temperature
Cause: Badly worn or broken spider gears
Noise: Banging or heavy clicking every 2-3 feet during acceleration and deceleration
Cause: Damaged or broken pinion gear tooth or teeth
Noise: Banging or heavy clicking every 2-3 feet during acceleration or deceleration, but not both
Cause: High spot or heavy chip on pinion gear tooth
Noise: Banging or heavy clicking every 8 feet during acceleration and deceleration
Cause: Damaged or broken ring gear tooth or teeth
Noise: Banging or heavy clicking every 8 feet during acceleration or deceleration, but not both
Cause: High spot or heavy chip on ring gear tooth
Noise: Clicking while decelerating from 20 miles per hour to a complete stop
Cause: Worn carrier case-side gear bores
Noise: Rumble or clicking that gets worse during hard turns
Cause: Bad wheel bearings
Noise: Driveline squeaking or grinding at any speed
Cause: Worn or damaged U-joints
Noise: Clunking when depressing the throttle pedal (takeoff)
Cause: Worn U-joints; worn spider gears; worn axle splines; excessive gear backlash; loose yoke splines; worn slip yoke splines
Noise: Clunk immediately after taking off from a stop
Cause: Worn slip yoke splines
Noise: Steady vibration that increases with speed
Cause: Worn U-joint or out-of-balance driveshaft
Noise: Cyclic vibration that varies in intensity. Intensity increases at a specific speed range, worsens during deceleration
Cause: Pinion angle too low (not parallel with front yoke on driveshaft)"
:23_1 0_13:
قديم 05-10-2012, 07:20 PM
الموقع: محافظة الجيزة
السلام عليكم جميعا إخوانى الكرام
مرحبا بكم فى الجزء الثالث من سلسلة حكايتى اللى بحاول أسرد فيها اللى بيحصل معايا بالظبط فى عربيتى ، واه اللى بعمله بالظبط علشان كلنا نستفاد
الموضوع بدأ معايا من يوم مافكيت العربية من جوا الصالون وكده
لاحظت ان الكارونة مع المشى وخصوصا فى السرعات من 80 ونتا طالع بيكون لها ونة
طبعا راجعت على الزيت لقيته تمام كان زيت 140 والدنيا زى الفل بس لاحظت ان فيه فايظ فى الكارونة من فوق وكان بيرشح زيت
الحاجة التانية انها كانت بتخبط مع المشى ونتا بتنقل الغيارات وخصوصا من الأول للتانى ومن التانى للتالت قولنا ماشى
لما لقيت الموضوع زاد روحت لواحد متخصص كوارين وفتايس فى حدايق القبة (الكلام ده كان قبل العيد الصغير اللى فات )
قاللى الكارونة مبوشة من جوا وهتحتاج عمود بنيون وترس تاج (تمنهم 1200 جنيه لو لقيتهم ) ونا من جوايا عارف ومتيقن ان كارونة ال131 والشاهين ضعيفة ومش بتاعت شغل
ده عمود البنيون :
المهم قولت ماشى اهى كده كده ماشية على ماتفرج وساعتها نشوف هنعمل اه
ساعتها استشرت ناس جميلة اوى من أعلام المنتدى فى الموضوع ده وقالولى على وصفات وخلطات عشان تكتم الصوت
وبالفعل عملت الوصفات وكانت بتكتم شوية وشوية وترجع تانى لكن كانت ماشية
والفايظ بتاع الزيت من فوق كان بينفخ وطبعا بتقل معايا الزيت وصوتها يعلى
المهم واحد صديقى من المنتدى قاللى انا عندى حلها واتفقت معاه اعدى عليه ونشتغل فيها
جبت حاجات بناءا على طلباته وبناءا على انه عملها قبل كده فى عربيته وعربية صديقه والحاجات اللى جبتها :
1- علبتين صنفرة روديه ناعم وخشن
2- كيلو شحم متعدد الأغراض
3- زيت فلفالين 140
4- علبة زيت شنبر
5- اويل سيل كارونة
6- جوان الكرتيرة اللى ورا بتاع الكارونة
بدأنا الشغل فيها من بعد العصر وعلى ماقفلناها كانت منتصف الليل
ملينا الزيت وطلعت جربت العربية تمام وزى الفل
ونا مروح بقى تفاقمت المشكلة
الكرونة صوتها بيخشن ، طيب اعمل اه أركن فين ونا كنت مروح من الدقى ورايح على التجمع وبتخشن ونا على كوبرى اكتوبر ، يعنى ماينفعش تقف
فضلت مسايسها خااااالص وماشى ع التانى من عند التحرير لحد مانزلت من كوبرى اكتوبر نزلة المقطم
طبعا من كتر السخونة الكارونة كانت هتقفش وقفت بيها واستنيت
بالعافية روحت البيت على الساعة 3 ونص وبرضو ماشى ع التانى عرفت ان خلااص مفيش امل وانها باظت ولازم أجيب واحدة جديدة
الساعة 4 الفجر وانا من امبارح فى الشارع ، قولت مش هروح غير لما اصلحها
والصراحة كنت حاسس انى اتعلم عليا
ونا نازل عزبة شلبى وبالظبط عند ميدان السواح كانت بتتكسر وقفشت خالص بعد الميدان بشوية
ركنتها ونزلت وكنت متفق مع واحد معرفة بيشتغل فى البولونيز سألته على الكارونة قاللى 750 جنيه
وكنت خلاص هجيبها وأعدلها على عربيتى وخصوصا انى مش بحب فرامل ال131
صاحبنا بقى ماجاش واتأخر قولت اتمشى شوية فى العزبة
كل اللى عنده كرونة 131 بيتكلم فى عمودين مقفولين وضمان أسبوع وفى واحد باشا بيقول 2300 وضمان شهر يافرحه الحاجة بيك
بالصدفة لقيت يافطة كبيرة مكتوب عليها سلامة أخصائى كوارين
131 يابانى وشاهين ولادا وبتاع قولت أكلمه
ايوه يا عم سلامة انت فين قاللى سوانى وأنزلك كانت الساعة 9 الصبح ولسه العزبة مفيهاش سريخ ابن يومين
حكيتله على اللى حصللى واللى دوشتكوا بيه ، قاللى انسى ماينفعش طبعا اللى عملته
وقاللى عندى حلها وراح مشاورلى على فارغة بتاعت 131 زى اللى راكبه عندى بالظبط
قاللى هتاخدها وتروح تركبها وتجيبلى القديمة وهتدفع 800 تما
قولتله زى الفل
طبعا كان يوم السبت ميعاد مقابلة رابطة ملاك السفينة ال132 كلمنى أستاذ/ مصطفى عاطف وعرف المشكلة اللى انا فيها وفى الحال قرر هو والأستاذ ايمن الروبى انهم يقابلونى
استنيت والحمد لله وصلوا بالسلامة أخدنا الفارغة وروحنا على العربية وفى الطريق إتصلت بمحمود عفشة صاحبى وفكينا القديمة وركبنا التانية
الأكسات كانت مختلفة رجعت على سلامة وأخدت منه أكسين جداد وركبتهم وطلعت بالعربية الحمدلله
لكن العربية كانت بترج جامد من سرعة 50 ونتا طالع حاجة تسد النفس وخصوصا بعد المصاريف اللى صرفتها
قعدت يومين راكن العربية ونفسى مقفوله منها اوى
المهم امبارح روحت على كمال الخراط متخصص فى الكرادين فى ميدان الظاهر بيبرس قرب باب الشعرية والحمدلله ظبط الكردان والعربية الحمدلله بقت كويسة
الكارونة تمنها 800 جنيه من عند سلامة فى عزبة شلبى
دروس وعبر :
ماتحاولش تفك كارونتك ولا تعمل فيها اى حاجة اهم حاجة ماتنقصش زيت
الكردان هو روح العربية ومهم اوى يتراجع عليه دوريا
سيبك من الخلطات والكلام اللى ملوش لازمة ده
اثبتت الفيات ان الجر الخلفى فاااااشل
طيب بالنسبة للكارونة الجديدة
هى كانت بتاعت اللادا الجيب ومشغولة جوا الفارغة بتاعت ال131 يعنى مش بتاعت 131 أصليه ، لكن بتقضى الحال وعلى أد تمنها
الكرونة اليابانى لل131 مشاكلها كتير على سبيل المثال لا الحصر الأكس لو حصل فيه حاجة بترمى الكارونة كلها
بتفوت الموتور بسرعة لأن اليابانى عير الفيات بالنسبة لمعدل الدوران ونقل العربية من الثبات ، ده غير مشاكل تانية ممكن تحصل فى الفتيس
ونسبة نحاجها 60 % او اقل لأن سلامة بيقوللى كان لسه عنده واحد مغير كرونة يابانى ب 1500 جنيه واترمت واخد واحدة تانية فيات من عنده
ادعولى ربنا يسترها معايا ومعاكم يارب لأن العربية دى كل ما أدفع فيها جنيه بتأدبنى بعشرة
بالنسبة للكارونة القديمة واللى حصل فيها انا متوقع اننا ماربطناش البنيون كويس وبالتالى فك ونا ماشى لكن الكردان حافظ على الفلانشة بتاعت الكارونة انها تفضل فى مكانها لكن البنيون قعد يلعب لحد مااتكسر وقفشت
ربنا يسترها معانا ومعاكم يارب وأى حد عاوز إستفسار فى الموضوع ده انا مش هتأخر عنكم
تحياتى وإحترامى
أخوكم هشام الجزار
الصنيعى الى حطلك السنفرة دة ما بيفهمش خالص وكمان سابلك الصمولة سايبة منو لله :Bra vo:: Bravo::Brav o:
قديم 05-10-2012, 07:25 PM
وطبعا مش هنسى كا رز ادمير وحمدى المخترع الف حمد وشكر ليك يارب ان حضرتك ما نستناش
قديم 08-10-2012, 10:26 AM
من انا؟: الفقير إلى الله
عاجل رد: حكايتـى......... مع الكارونة
[QUOTE=cars admire;772659][QUOTE=Hisham.Elgazzar;771 912]
/QUOTE]
[QUOTE=حمدى مخترع مانيوال بدون د;772721]الصنيعى الى حطلك السنفرة دة ما بيفهمش خالص وكمان سابلك الصمولة سايبة منو لله QUOTE]
المشاركة الأصلية كتبت بواسطة حمدى مخترع مانيوال بدون د مشاهدة المشاركة
AHLN WSHALNAHLNWSHAL NAHLN WSHALNAHLNWSHAL NAHLN WSHALNAHLNWSHAL N
الساعة الآن 05:59 PM.
