العودة   مصر موتورز مجتمع السيارات > السيارات الأوروبية > فولفو Volvo
فولفو Volvo فولفو Volvo هي شركة سويدية لتصنيع السيارات والسيارات الثقيلة تم إنشاؤها سنة 1927 ورغم النجاح المحدود للشركة على الصعيد التجارى الا ان الشركة طالما تميزت بالتزامها باقصى معايير السلامة والامان فى سياراتها مما جعلها رمزاً للسيارات الامنة فى العالم
قديم 18-12-2011, 11:44 PM
افتراضي رد: صور موديلات الفولفو
cars admire u must enter gens records
موسوعه في العربيات
قديم 10-09-2012, 07:17 PM
:C HUBBY~36::CHUBBY~36 :
قديم 10-09-2012, 07:24 PM
الصورة الرمزية mhamdy75
أدمير= موسوعة متكاملة للسيارات
مهندس / محمد حمدى
قديم 10-09-2012, 09:41 PM
افتراضي رد: DAF 66,55,45,33 & VOLVO 66
Volvo 343 & 300 (1976-1986)
1976 Volvo 343 DL
The 343 was designed by DAF before the take-over by Volvo, although DAF never manufactured it themselves.
1976 Volvo 343 DL
Two cylinder air-cooled boxer engine? Check. Pressurized Lubrication System? Check. Rear-wheel drive? Check. Independent rear suspension? Check. Continuously variable transmission? Check. Each rear wheel driven by a rubber belt? What in the fuck?!? Welcome to the wonderfully whacked out world of DAF. Mind blowing mechanical coolness after the jump.
This is the Variomatic transmission system of the DAF 33, including the rear wheels and the independent suspension system. Each rear wheel had its own homokinetic belt drive, this way the transmission also functioned as a self-locking differential. This transmission system was developed by Johan van der Brugghen and quite special as you can see. You can also clearly see the two pairs of conical metal wheels (called "pulleys") in between which the rubber belt is wedged. In the position shown on the picture the transmission would have been in (almost) lowest gear: a small gear diameter at the driveshaft side and a large gear diameter at the belt driven rear wheel side. In highest gear it would be the other way around: the conical wheels at the driveshaft side would move together, forcing the rubber band to the outside to create a larger gear diameter. At the same time the conical wheels in the transmission at the rear wheel side would move further apart, letting the belt in to create a smaller gear diameter.
So the whole system was friction operated and that was also its main drawback: it made a high whining noise when changing gear ratios and the belts wore out and stretched after some time, causing them to snap or slip out of the transmission. It was very important to change the belts in time, otherwise the driver could end up at the side of the road quite unexpectedly.
:14369D~14 9::14369D~149 :
ياريت توضيح بسيط عن سبب تركيب العجل بعيد عن الكارونه ونقل الحركه عن طريق سير
قديم 11-09-2012, 07:10 AM
حصرى رد: صور موديلات الفولفو
المشاركة الأصلية كتبت بواسطة mhamdy75 مشاهدة المشاركة
mhamdy75
:C HUBBY~36:
mhamdy75
:G ROWIN~12:
volvo
الساعة الآن 09:27 PM.
