قديم 09-03-2011, 05:48 PM
للاهمية رد: ممكن مساعدة "عندى اختراع جديد" خاص بناقل الحركة العادى
yes right
indeed
Citroen is one manufacturer that committed to semi automatic transmission. First appearing in 1955 on the Citroen DS, an hydraulic system
Semi-automatic transmission, or clutchless manual transmission, is a system which uses electronic sensors, processors and actuators to do gear shifts on the command of the driver. This removes the need for a clutch pedal which the driver needs to depress before making a gear change, since the clutch itself is actuated by electronic equipment which can synchronise the timing and torque required to make gear shifts quick and smooth. The system was designed by European automobile manufacturers to provide a better driving experience, especially in cities where congestion frequently causes stop-and-go traffic patterns.
In standard mass-production automobiles, the gear lever appears similar to manual shifts, except that the shift stick only moves forward and backward to shift into higher and lower gears respectively, instead of the traditional H-pattern. The Bugatti Veyron uses this approach for its 7-speed transmission. In Formula One, the system is adapted to fit onto the steering wheel in the form of two paddles; depressing the right paddle shifts into a higher gear, while depressing the left paddle shifts into a lower one. Numerous road cars have inherited the same mechanism.
Hall effect sensors sense the direction of requested shift, and this input, together with a sensor in the gear box which senses the current speed and gear selected, feeds into a central processing unit. This unit then determines the optimal timing and torque required for a smooth clutch engagement, based on input from these two sensors as well as other factors, such as engine rotation, the Electronic Stability Program, air conditioner and dashboard instruments.
The central processing unit powers a hydro-mechanical unit to either engage or disengage the clutch, which is kept in close synchronization with the gear-shifting action the driver has started. The hydro-mechanical unit contains a servomotor coupled to a gear arrangement for a linear actuator, which uses brake fluid from the braking system to impel a hydraulic cylinder to move the main clutch actuator.
The power of the system lies in the fact that electronic equipment can react much faster and more precisely than a human, and takes advantage of the precision of electronic signals to allow a complete clutch operation without the intervention of the driver.
Historically, the first semi-automatic transmission which was marketed was the 1941 M4/Vacamatic Transmission by Chrysler. It was an early attempt at an automatic transmission that still required the use of a clutch, primarily to start and stop. Later, the Volkswagen Beetle came with an optional "Autostick", which was essentially a clutchless manual with three forward gears.
Citroen is one manufacturer that committed to semi automatic transmission. First appearing in 1955 on the Citroen DS, an hydraulic system was used to select gears and operate the conventional clutch using hydraulic servos. There was also a speed controller and idle speed step-up device, all hydraulically operated. This was a clutchless shifting with a single column mounted selector. The Citroen 2CV gained a device named 'Trafficlutch', a centrefugal clutch that enabled clutchless changes in the first two ratios only (for town driving). The DS's semi automatic transmission was nicknamed 'Citro-Matic' in the United States. Later, the manufacturer introduced optional semi automatic transmissions on their medium and large saloon and estate models in the 1970s; the Citroen GS and CX models had the option of 3 speed, semiautomatic transmission marketed as 'C matic'. This was simpler than the previous inasmuch as it used a floor mounted quadrant lever operating a contact breaker and conventional gear selector rods in series, a fluid coupling 'torque convertor' and wet plate clutch were cut in and out of phase by an electro valve controlled by the contact breaker. This system was simple in that it dispensed with the former use of hydraulics to operate a clutch AND select the gear ratios. Citroen semi automatic transmission of this era made no use of electronics, the entire gear selecting operation was carried out by simply moving the gear lever from one ratio to the next.
The German automobile manufacturer, NSU, produced a semi automatic system for the rotary engined Ro80 saloon car in the 1960s, similar in concept to Citroen's system except that it used an electric switch on the gear shifter which disengaged the clutch.
Drag Racers have their own type of clutchless manual transmissions. A Liberty is basically a manual transmission with no clutch, and is used in Pro Stock. The Lenco is a transmisson also used in drag racers. A Lenco is different from a Liberty because a Lenco uses planetary gears, like an automatic. Both transmissions can be manually shifted, or use an air shifter. However, they require a clutch to use when leaving off the line for traction. The Lenco uses separate levers to shift while the Liberty uses a single shifter hooked up to several levers. A variation of the Lenco called a Lencodrive utilizes a torque converter and no clutch.
Some variants of the system, such as Citroën's Sensodrive, allow the driver to select automatic mode, in which the processor takes responsibility for gear changes. The car then drives much like a standard automatic, including features such as kickdown, but with fuel consumption pretty similar to a manual. Gears can be selected using either stick or paddles, both in manual control and as a temporal change in automatic mode (for example before starting to overtake another car).
Semi-automatic transmissions have also made its way into the truck and bus market in the early 2000s. Volvo offers its i-Shift on its heavier trucks and buses, while ZF Friedrichshafen AG markets its ASTronic system for buses and coaches. These gearboxes have a place in public transport as they have been shown to significantly reduce fuel consumption.
قديم 09-03-2011, 05:56 PM
حصرى رد: ممكن مساعدة "عندى اختراع جديد" خاص بناقل الحركة العادى
Sensonic Transmission: All the control of a manual, but no clutch to pump! I borrowed one of these for a day, they make driving in town traffic really easy since there is no clutch and you just crawl along in first with just the accelerator (gas pedal), but you have all the fun of a manual transmission for scooting round country lanes. To change gear, just ease off on the accelerator and move the stick !!
Driving the Sensonic for the first time is very strange, you must make a conscious effort to keep your left foot on the floor. There is a great temptation to do something with your left foot, especially the first few times when getting into the car. With luck you will stamp the floor, stamping on the brake pedal when you want to change gear is not recommended !!
Also you still have to use the handbrake when starting on a hill otherwise the car will roll back. Also if you leave it in gear without moving forward, the dashboard will chime and you will get a polite "DISENGAGE GEAR" warning.
the driver in this film had a left broken leg then that meant
no clutch for this car inspite of it is completely manual
gearbox yet
http://www.masrmotors.com/vb/showthread.php?t=42171
التعديل الأخير تم بواسطة cars admire ; 09-03-2011 الساعة 06:03 PM
قديم 09-03-2011, 06:48 PM
king2islam king2islam غير متواجد حالياً
king2islam is a jewel in the roughking2islam is a jewel in the roughking2islam is a jewel in the rough
افتراضي رد: ممكن مساعدة "عندى اختراع جديد" خاص بناقل الحركة العادى
thanks for your replay
im really happy for this but if you notes that`s my invention is a big Different between what you talk about my device is work as your device work and more then here in this video i see that`s he shift the gear manual but my device dont work like this my device will change the gear automatic no need for the hand to shift the gear
and you can to choose the mode:
  1. drive with the normal manual that`s mean you will use the clutch and you will use your hand to shift the gear
  2. or you can use the automatic mode that`s you dont need to use the clutch or shift the gear by your hand
  3. or use as your device work change the gear by your hand and you will not use the clutch
see that`s a big Different between my device and yours :14369D~14 9:
قديم 09-03-2011, 06:54 PM
التخصص العملى: accountant
بالتوفيق ان شاء الله
قديم 09-03-2011, 07:16 PM
المشاركة الأصلية كتبت بواسطة king2islam مشاهدة المشاركة
have a good luck and god help you
i would like to see video over here about what you will do ok deal?????
thank you any way
الساعة الآن 09:16 AM.
