قديم 29-09-2011, 10:48 AM
romioromio romioromio غير متواجد حالياً
التخصص العملى: طبيب
romioromio has a reputation beyond reputeromioromio has a reputation beyond reputeromioromio has a reputation beyond reputeromioromio has a reputation beyond reputeromioromio has a reputation beyond reputeromioromio has a reputation beyond reputeromioromio has a reputation beyond reputeromioromio has a reputation beyond reputeromioromio has a reputation beyond reputeromioromio has a reputation beyond reputeromioromio has a reputation beyond repute
افتراضي رد: العربيه بقت بتنتش ممكن يكون ده السبب
فعلا هو العكس تمام
انا اصلا لما ركبيته كان الفرامل محجره
حتي انا سالت في نفس الموضوع وكتبتها
لكن لما فكيته العربيه فاقت
وفعلا لازم ادوس دبرياج شويه لانها بتكون عايزه تطير او تامرك علي الاول
لكن لما كنت مركبه
كان لازم اكبس بنزين قوي عشان متبرجلش
اخيرا مش الفكره يا جماعه انك تركبه او تشيله
هو اساسا ساعات بيكون بايظ وله اعراض
وخدوها اهي
If the EGR valve is stuck open, it will essentially cause a vacuum leak, leading to inefficient combustion, rough idling, hesitation, and sometimes stalling in extreme cases . This is because the car cannot combust on carbon dioxide from the tailpipe — it needs atmospheric oxygen. If the combustion chamber is flooded with exhaust from an open EGR valve, it will not function properly. To check and see if the EGR valve is stuck open, have someone idle a parked vehicle with the brake on while you examine the plunger shaft to see if it is stuck open.
If the EGR valve is stuck closed, emissions of nitrogen oxides will rise, and the car may start to knock. Spark knock happens when the fuel mixture in the combustion chamber ignites before it has been reached by the explosion in the cylinder, resulting in a disruption of the engine timing. In this instance, the engine should be warmed up and revved to see if the EGR valve will move
اخيرا
انا اصلا مش فاكه من ناحية الصمام او الرق اللي لازق في الماتور
انا فاكه من الناحية التانيه من فوق
بعدين انا اصلا اشتريت العربيه وكان صاحبه فاكه برده
قديم 29-09-2011, 05:26 PM
amro atif amro atif غير متواجد حالياً
التخصص العملى: طبيب اسنان
الموقع: المنصوره
amro atif is a splendid one to beholdamro atif is a splendid one to beholdamro atif is a splendid one to beholdamro atif is a splendid one to beholdamro atif is a splendid one to beholdamro atif is a splendid one to behold
يا د عمرو
أكيد حضرتك تقصد ال pcv لكن ال egr حاجة تانية
ده غير فرق التصميم بين العربيتين دي ليجانزا و دي أوبترا بصراحة انا ماشوفتش ماتور الاوبترا
تمام يا باش مهندس اللي انا اقصدو خرطوم ال pcv
دايما يخرب الفالف دا ومفيش حد بياخد بالو انو لازم يتغير كل فتره وفي كتيبات الصيانه مذكور تغييره لانو مهم جدا للعربيه
أشكرك
عجبا للزمان في حالتيه وبلاء ذهبت منه اليه
رب يوم بكيت منـــــــه فلما تولى بكيت عليـه
قديم 21-03-2013, 10:36 AM
محمد كامل محمد محمد كامل محمد غير متواجد حالياً
محمد كامل محمد is on a distinguished road
كيفية ضبط اسبراتير السيارة ماروتي موديل 2009 800cc
قديم 06-05-2013, 06:49 PM
الصورة الرمزية diaahsn
diaahsn diaahsn غير متواجد حالياً
من انا؟: veterinarian
التخصص العملى: veterinarian
هواياتي: playstation
الموقع: الشيخ زايد
diaahsn is a jewel in the roughdiaahsn is a jewel in the roughdiaahsn is a jewel in the roughdiaahsn is a jewel in the rough
موضوع مفيد جدا
سبحان الله وبحمدة سبحان العظيم
قديم 06-05-2013, 06:58 PM
adamlion adamlion غير متواجد حالياً
adamlion is a splendid one to beholdadamlion is a splendid one to beholdadamlion is a splendid one to beholdadamlion is a splendid one to beholdadamlion is a splendid one to beholdadamlion is a splendid one to beholdadamlion is a splendid one to beholdadamlion is a splendid one to behold
روح لميكانيكى لان الفرامل بالذات لاتحتتمل التجارب وخليه ييغيرالبوجيهات ان شاء الله هتروح التنتيشه
الساعة الآن 06:31 PM.
