قديم 08-03-2011, 06:56 AM
افتراضي رد: ممكن مساعدة "عندى اختراع جديد" خاص بناقل الحركة العادى
المشاركة الأصلية كتبت بواسطة king2islam مشاهدة المشاركة
thanks for your replay
im already know that`s you are here in egypt if you not how you read my notes
but you still dont answer my Q about that`s device
About Your Transmission
There are two basic types of transmissions, the automatic transmission and the manual transmission. As their names imply one changes gears automatically and the other is changed manually.
Manual Transmission
The manual transmission consists of a series of gears that convert the engine speed into vehicle speed by changing the ratio between engine speed and the drive axles. Because the engine is always running the clutch disengages the transmission form the engine when it is depressed. Thus allowing the engine to continue running while the vehicle is stationary. Releasing the clutch will engage the transmission with the engine and allow the vehicle to move. As the engine speed increases it is necessary to shift the gears in the transmission in order to gain speed while allowing the engine speed to remain at a safe level. This is accomplished by releasing the gas pedal, depressing the clutch, shifting the transmission and then releasing the clutch while depressing the throttle at the same time.
Automatic Transmission
The automatic transmission performs the same function as the manual transmission but in a much more seemingly simple way. The automatic transmission however is much more complicated than the manual. The automatic transmission uses a torque converter, gears, clutches, hydraulics, sensors and in most cases computers to shift gears all by simply putting the vehicle in drive. The automatic transmission is the most complicated and sophisticated device on your car and because it is it requires more frequent maintenance than the manual transmission.
Both types of transmissions will require maintenance and you should refer to your owners manual for all maintenance intervals as well as types of fluid to use and the amount necessary to service them.
There are two basic types of maintenance services that can be performed on your transmission. Proper maintenance is essential to maximizing the life and performance of your transmission.
Conventional Transmission Service – Involves removing the transmission oil pan, replacing the transmission filter and gasket, and then re-installing the transmission oil pan. This type of service typically replaces only approximately 1/3 of the transmission fluid, leaving 2/3 of the contaminated fluid behind.
Transmission Flush – An alternative modern method which involves adding a cleaning agent to the contaminated fluid, circulating it in the transmission until the transmission reaches operating temperature, and then flushing the transmission with more fluid than is necessary to fill it from empty. This ensures that all of the contaminated fluid is removed from the transmission as well as the torque converter.
If you are shopping around for transmission service, be sure to ask about the transmission flush. Many Fort Wayne transmission shops will perform the conventional service – it is cheaper, but cuts corners that could pose long term danger to your transmission. Trust your transmission to a Fort Wayne shop that does things the right way.
Symptoms of Transmission Problems
If you are concerned about your transmission, it’s better that you contact a qualified technician sooner rather than later to prevent potential damage to your transmission. Your Fort Wayne transmission experts at Tomkinson Automotive can answer your questions about signs of transmission trouble. Feel free to call us at 260-436-6200 with any questions you may have. The most common symptoms of transmission trouble can be a variety of things including any of the following:
-Malfunction lights coming on, on the dash that indicate you have a problem.
-Red-colored fluid leaks on the ground.
-Erratic shifting of the transmission while driving.
-Hesitation of the transmission when put into reverse or drive.
Convert your car into a Semi-Automatic car
Hassle Free Car driving for Indian
Women unlike earlier though are now become active in car driving influencing the market in many ways, they are still perceived worldwide as reckless drivers. Many may not accept this fact but various interesting statistics and findings do represent some disparity in female driving compared to male driving.There are lots of allegations made about women drivers because they cause more crashes than men. However, women are still coming 'on road' and some are even expertise in driving. But the number of proficient female drivers is very small.As you know car driving requires a continues coordination of Clutch, Brakes & Accelerator, specially when u are driving in Heavy Traffic congestion, or driving at up hill or driving in initial gears.City Clutch is a device which can gives complete freedom from the coordination of Clutch, Brake and Accelerator. After Installing the City Clutch, the Clutch of your car becomes totally Automatic, so as a drivers you only have to take car read more
February 9th, 2010 at 06:39 am
Details about post Installation of City Clutch in a car
So many times people ask us about how we do this semiautomatic conversion in a car practically and what kind of changes they will see physically? how much driving space will be occupied after installation & do the car will be still able to drive as a normal car or not? Do a normal person can drive that car manually or not ? Here I m describing the post installation stage with a pic of a Ford Fiesta Model car we have recently installed. Just click this pic to see the enlarged version 1. The Device :- The city Clutch device is designed to place easily below the drivers seat. 2. Mode Switch :- This is a ON/OFF mode switch which can be installed on any where on your car's dashboard to provide the choice of disabling or enabling the automatic clutch system. In OFF mode, device will be disabled and you can drive the car and clutch pedal manually using your left foot. In ON Mode, the device will be active and clutch pedal will move automatically. no need of using your read more
April 25th, 2009 at 12:49 am
What Exactly City Clutch is ???
City Clutch is a simple device (to convert your car into semi-automatic one) which can be installed in any model of car without any modification in Engine or in Gear box, and or no disturbance to the inner beauty of Car at all. City Cluth takes care of the clutch movement completely, it makes your left leg completely free, while driving. In other words it can convert your manual clutch into an automatic clutch system.Only at the time of Gear changing you need to push a simple switch installed on the gear knob. In normal driving condition the clutch moves automatically as per your driving habit. You can easily by pass the device by turning off a switch pro read more
March 6th, 2009 at 08:19 am / #car modification #semi-automatic car #semi automatic car #car driving for physically handicapped
Are you Tired of Driving in Traffic Congesion ??
Traffic congestion is a serious problem in most Indian metros. The scorching pace of economic growth and the growing incomes of India’s burgeoning middle class are only likely to make the situation worse. Public transport systems are overloaded, and there is a limit on how much additional infrastructure such as roads and rail lines a city can add. The autorities are trying the best to they can to cope with the increasing stress on the transportation infrastructure.Most of the time the stop & go pattern of Traffic Congestion distroy the joy of driving your luxirious car.How to Avoid the physical stress of co-ordinating the Clutch, Brake & Accelarator evertytime in a traffic congesion so that your vehicle don't stall frequently in such a traffic? The Answer is simple Install City Clutch in your car, irrespective of what model you have whether its a diesel or petrol , or AC or a Non AC, may be a Liguid driven or a Gas driven doesn't matter.The device City Clutch completely takes read more
March 5th, 2009 at 06:48 am
City Clutch is a simple device (to convert your car into semi-automatic one) which can be installed in any model of car without any modification in Engine or in Gear box, and or no disturbance to the inner beauty of Car at all.City Cluth takes care of the clutch movement completely, it makes your left leg completely free, while driving. In other words it can convert your manual clutch into an automatic clutch system.Only at the time of Gear changing you need to push a simple switch installed on the gear knob. In normal driving condition the clutch moves automatically as per your driving habit.you can easily by pass the device by turning off a switch provided on the dashboard and drive your car as a normal manual car. City Clutch is a device which is totally isolated from Engine. It is not based on Engine RPM so whether its a AC or a Non AC vehicle it doesn't effect the performance of the device. read more
February 10th, 2009 at 01:48 am / #car modification #semi-automatic car #semi automatic car #car driving for physically handicapped
What is Semi-Automatic ?
A semi-automatic transmission (also known as clutchless manual transmission or automated manual transmission. This system removes the need for a clutch pedal which the driver otherwise needs to depress before making a gear change. The clutch itself is actuated by electronic computer which can synchronise the timing and torque required to make gear shifts. The automatic clutch pedal System provides a better driving experience, especially in cities where congestion frequently causes stop-and-go traffic patterns. In City Clutch (The automatic Clutch Pedal Control System), We have developed a chip which analysizes diferent signals like speed sensor of the car, movement of Brake padel, Accelarato read more
February 2nd, 2009 at 04:46 am / #car modification #semi-automatic car #semi automatic car #car driving for physically handicapped #car modifier
A semi-automatic transmission (also known as clutchless manual transmission or automated manual transmission. This system removes the need for a clutch pedal which the driver otherwise needs to depress before making a gear change. The clutch itself is actuated by electronic computer which can synchronise the timing and torque required to make gear shifts. The automatic clutch pedal System provides a better driving experience, especially in cities where congestion frequently causes stop-and-go traffic patterns. In City Clutch (The automatic Clutch Pedal Control System), We have developed a chip which analysizes diferent signals like speed sensor of the car, movement of Brake padel, Accelarator padel etc. This electronic chip actuates the clutch pedal to move automatically as per your driving.The pic in the article shows how in our device "City clutch" we provide the facilty to convert your car into semi-automatic one. read more
January 26th, 2009 at 10:33 pm / #car modification #semi-automatic car #semi automatic car #car driving for physically handicapped #car modifier
Car Modification for Semi-Automatic one
Are you finding Answers for any of the following Question regarding Car Driving or car Modification ?~ Just Read Carefully the following :- ~ Looking for a device which can make your car to a semi-automatic one.~ Any device which can give you option of converting the clutch into an automatic clutch system so that you don't have to stress your left foot in heavey traffic congestion ?~ Looking for a pleasure of driving without using ur left foot for Clutch system~ Looking for a device which gives freedom from using left foot but also s read more
January 26th, 2009 at 05:28 am / #car modification #semi-automatic car #semi automatic car #car driving for physically handicapped #car modifier
Advantages of City Clutch
1. No-Clutch FunctionLike an automatic vehicle, start and stop can be conducted only by the accelerator and brake system without using the left foot as much as manual geared vehicles. Therefore the physical effort is reduced while driving. 2. Interchange of Manual and Automatic(Multi-Function System)Whenever the clutch-pedal is pressed down, it changes to manual state. Hence, the manual system and automatic system are interchangeable. 3. Economic-Viability and Environmental ConcernThe fuel consumption is similar to an ordinary manually geared vehicle, which means that the fuel consumption rate is 20%~30% lower than the automatic one. Therefore it is more economically viable. Along with this advantage, the air pollution due to automobile exhaustion is reduced, contributing to the environmental protection. 4. Adaptable And TransferableThe CITY CLUTCH system can be read more
January 21st, 2009 at 10:46 pm / #car modification #semi-automatic car #semi automatic car #car driving for physically handicapped #car modifier
The Major Parts Of City Clutch
Hand Knob SwitchThe Red push button shown in the pic.During gear-change, you can change the gear by just holding the HAND KNOB Switch to press the clutch, instead of pedaling the clutch pedal. Clutch ActuatorAs a machine part, it pulls or pushes the CLUTCH SLAVE CYLINDER or RELEASE POKE with the help of the motion of the motor and hence allow the attachment and detachment of the CLUTCH DISK. ComputerIt is an electronic control equipment that sends the control signal to pull or push the CLUTCH ACTUATOR according to the signals finputted by the vehicle's self- sensors or other additional sensors, so that the control of the clutch is satisfactory read more
January 21st, 2009 at 10:44 pm / #car modification #semi-automatic car #semi automatic car #car driving for physically handicapped #car modifier
Are you finding Answers for any of the following Question regarding Car Driving or car Modification ?~ Just Read Carefully the following :-~ Looking for a device which can make your car to a semi-automatic one.~ Any device which can give you option of converting the clutch into an automatic clutch system so that you don't have to stress your left foot in heavey traffic congestion ?~ Looking for a pleasure of driving without using ur left foot for Clutch system ~ Looking for a device which gives freedom from using left foot but also should not stress on extra effort from left hand too ?~ Any Device available for semi-automatic conversion which do not requires any modification in existing interior/ exterior of my car or no any gear box modification ? ~ How a Physically Handicapped person can drive a car ?~ How a Polio Infected person in Left leg can drive a car ?~ Is there any device available for Hand control operations(just push of a switch) in car easily ? ~ What kind of Car Modifica read more
January 19th, 2009 at 05:08 am / #car modification #semi-automatic car #semi automatic car #car driving for physically handicapped #car modifier
Frequently Asked Question about this simple Device...
What happens during an emergency stop?-During braking CITY CLUTCH will ensure that the engine remains coupled in assis the deceleration process, and automtically disengages the clutch just before the car comes to a complete stop. The engine will therefore not stall. Thus, behaving in exactly the same manner as you are accustomed to. Can CITY CLUTCH be switched off?-Yes it can. There is an On/Off switch. This can be switched on or off even while moving. Will CITY CLUTCH result in higher clutch plate wear?-No. CITY CLUTCH has a balanced method of clutch engagement, clutch plate wear for an average driving style is certainly no more than for normal use. Will any modifications be made to my car?-CITY CLUTCH can be installed without any modifications to your car's system The only alterations are that a number of attachment points are introduced for the installation of compo read more
January 17th, 2009 at 12:13 am / #car modification #semi-automatic car #semi automatic car #car driving for physically handicapped #car modifier
CITY CLUTCH Freedom to Drive...........
Automatic or Manual why Not Have both ....???City Clutch ( AutoClutch System) is a device developed with a deep thought of Freedom to drive by a Innovitive Engineer. City Clutch is a Automatic Clutch Pedal Control System ( ACPCS). Which gives Complete Freedom to Drive. With City Clutch you can convert a manual Car ( Manual Transmission) into a Semi-Automatic Transmission, at the touch of a button. Key Benefits of City Clutch:-• Change Gear without using your Foot to operate the clutch • No Engine or Gear Modifications • Less Physical Stress • Transfer to your next car • Easy to Use • Can be switched ON or OFF even while driving • Crawls like an Automatic Transmission • Available for all types of Cars & Light Duty Vans • More Fuel Economical than automatic Transmission read more
January 17th, 2009 at 12:12 am / #car modification #semi-automatic car #semi automatic car #car driving for physically handicapped #car modifier
1. No-Clutch FunctionLike an automatic vehicle, start and stop can be conducted only by the accelerator and brake system without using the left foot as much as manual geared vehicles. Therefore the physical effort is reduced while driving.2. Interchange of Manual and Automatic(Multi-Function System)Whenever the clutch-pedal is pressed down, it changes to manual state. Hence, the manual system and automatic system are interchangeable.3. Economic-Viability and Environmental ConcernThe fuel consumption is similar to an ordinary manually geared vehicle, which means that the fuel consumption rate is 20%~30% lower than the automatic one. Therefore it is more economically viable. Along with this advantage, the air pollution due to automobile exhaustion is reduced, contributing to the environmental protection.4. Adaptable And TransferableThe CITY CLUTCH system can be installed in any domestic or foreign vehicle and can be easily transferred from one vehicle to another, incurring only labor and read more
September 17th, 2008 at 05:46 am / #car modification #semi-automatic car #semi automatic car #car driving for physically handicapped #car modifier
Hand Knob SwitchThe Red push button shown in the pic.During gear-change, you can change the gear by just holding the HAND KNOB Switch to press the clutch, instead of pedaling the clutch pedal.Clutch ActuatorAs a machine part, it pulls or pushes the CLUTCH SLAVE CYLINDER or RELEASE POKE with the help of the motion of the motor and hence allow the attachment and detachment of the CLUTCH DISK.ComputerIt is an electronic control equipment that sends the control signal to pull or push the CLUTCH ACTUATOR according to the signals finputted by the vehicle's self- sensors or other additional sensors, so that the control of the clutch is satisfactory read more
September 17th, 2008 at 05:30 am / #car modification #semi-automatic car #semi automatic car #car driving for physically handicapped #car modifier
قديم 08-03-2011, 04:39 PM
king2islam king2islam غير متواجد حالياً
king2islam is a jewel in the roughking2islam is a jewel in the roughking2islam is a jewel in the rough
thanks a lot for your replaying i notes that`s your device you talk about is sami automatic what`s that mean you mean that`s when i push the red button to change the gear ???!!!! or that` device can give the gear automatic ? plz answer my Q
قديم 08-03-2011, 04:57 PM
i meant that`s when i push the red button to change the gear
red button will working looks like the same
cLutch
pedaL
read it as well again slowly
you can have the pleasure of clutch free driving.
NO Need of using your Left Foot at all after installing this device.
Very Useful for Physically challenged, female drivers, old age people, Traffic congestion & and for those who are looking for the joy of Automatic driving in their own car.
NO modification in Engine or Gear box. we don't even disturb the inner beauty of your car.
contact at 09825065934 or visit at www.semiautomaticar.blogspot.com.
Control your car by only brake pedal in heavy traffic congestion and reduce physical stress
قديم 09-03-2011, 02:11 AM
that`s good but that`s mean that your device can not change the gear automatic ?????????
قديم 09-03-2011, 04:20 PM
yes right
indeed
الساعة الآن 11:48 AM.
