قديم 08-07-2010, 02:40 AM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
BMW M5 production comes to an end [w/video]
Filed under: , , , ,
2008 BMW M5 - Click above for high-res image gallery
The King is dead, long live the King. BMW dropped us a line to say that the V10-powered M5 supersedan is no more. Production has officially ended on the E60 version of one the world's best sports sedan after five years and 20,548 units. That's even greater than the production numbers of its predecessor, the V8-powered E39 models, even though those versions had an additional year of production.
When it was first released in 2005 as a 2006 model, the E60 was a fairly outrageous automotive offering, with an exotic 5.0-liter V10 and 507 horsepower on tap. This generation of M5 introduced the world to a whole new set of superlatives as automotive journalists reached for their Roget's to find a novel way to describe the acceleration, braking and handling. And now that the E60 is no more.
But BMW wants us to rejoice rather than lament the passing of the E60, for the new F10 BMW M5 is just around der Karussell. We've been seeing spy shots of the 2011 BMW M5 seemingly forever, and with its new twin-turbocharged 4.4-liter V8 rumored to be producing 560 horsepower and 530 pound-feet of torque, performance should even be a step above the E60. That doesn't mean we won't miss the E60, however. The good news is that they should be getting even more affordable on the used car market. Follow the jump to read the release and check out a few of our favorite E60 M5 reviews from the blokes at Top Gear and their more sane siblings at Fifth Gear.
[Source: BMW]
Continue reading BMW M5 production comes to an end [w/video]
BMW M5 production comes to an end [w/video] originally appeared on Autoblog on Wed, 07 Jul 2010 19:24:00 EST. Please see our terms for use of feeds.
أكثر...
قديم 08-07-2010, 06:40 PM
مراسل مصر موتورز
الموقع: مصر
Spy Shots: BMW 6 Series Cabriolet takes its top off
Filed under: , , ,
The BMW 6 Series Cabriolet is in the latter stages of pre-reveal testing, but has only now been caught in spy shots with its top down. The car's cloth-top lines are the same as on the current generation, slightly arched on top and running down into buttresses on either side of the vertical rear window that also serves as a wind deflector.
Even on the slightly rounder 2010 6 Series Cab, putting the top down makes the car seem a little longer. But with the streamlined body of the next iteration giving the appearance of more length in general, to our eyes this new car is fills our field of vision like the S.S. Tirpitz with its top stowed. Even so, 7 Series engines should give it plenty of motivation.
We look forward to checking it out at the Paris Motor Show in 90 days, if it fits...
[Source: GMotors Ireland]
Spy Shots: BMW 6 Series Cabriolet takes its top off originally appeared on Autoblog on Thu, 08 Jul 2010 11:31:00 EST. Please see our terms for use of feeds.
Read | Permalink | Email this | Comments
أكثر...
قديم 08-07-2010, 08:10 PM
مراسل مصر موتورز
الموقع: مصر
2011 Alpina B5 Bi-Turbo - Full details and images
2011 Alpina B5 Bi-Turbo - Click above for high-res image gallery
Alpina has finally graced the world with a handful of images and all of the gritty details about the all-new 2011 B5 Bi-Turbo after its debut at the Goodwood Festival of Speed. The company has managed to bless the BMW 5 Series with a mythic 507 horsepower and 516 lb-ft of torque. How, you ask? The B5 makes use of the same twin-turbo, all aluminum V8 found in the car's big brother, the B7. That means that there's a full 4.4-liters of displacement sucking down 1 bar of pressure for the two turbos under the hood. Sounds like a party.
The eight-pot is bolted to an eight-speed automatic transmission that Alpina co-developed with the gear-swapping gurus at ZF. If the mood strikes you, the driver can click through the gears via buttons mounted on the back side of the steering wheel, though given the massive amount of work Alpina put into the transmission, odds are you're better off letting the car do the work for you.
There's also a completely reworked suspension on board that includes slightly shorter springs and unique control arms that help eek a little more camber out of the front wheels. Combined with the electronically adjustable suspension, the company claims to provide an altogether sharper driving experience. Speaking of wheels, Alpina has equipped the B5 Bi-Turbo with a set of the company's epic 20-inch rollers. Check out the gallery of high-res images below and then click past the jump for the granddaddy of a press blast.
[Source: Alpina]
Continue reading 2011 Alpina B5 Bi-Turbo - Full details and images
2011 Alpina B5 Bi-Turbo - Full details and images originally appeared on Autoblog on Thu, 08 Jul 2010 13:01:00 EST. Please see our terms for use of feeds.
أكثر...
قديم 09-07-2010, 03:10 AM
مراسل مصر موتورز
الموقع: مصر
Video: BMW teases 1 Series M Coupe
Filed under: , , ,
BMW 1 Series M Coupe - Click above to view the video after the jump
We've waited a long time for this. And not just for the official name. BMW has released the first teaser video of its upcoming 1 Series M Coupe and "excited" doesn't begin to describe how we're feeling.
The video after the jump is devoid of hard details, but it confirms what we've seen in countless spy shots and the rumors that have made the rounds for nearly a year.
Early reports indicate that the turbocharged inline-six in the standard 135i will be upgraded to around 350 horsepower and 310 pound-feet of torque. The M Coupe's newfound grunt will be channeled through a six-speed dual-clutch gearbox and to the rear wheels via a torque-vectoring M rear differential, resulting in a 0-60 time of around 4.3 to 4.5 seconds.
Naturally, firmer springs, dampers and bushings are part of the package, along with lightweight 18-inch wheels and a full body kit consisting of a new fascia, flared wheel arches, larger side sills, rear diffuser and a small spoiler. Being an M-fettled product, expect a quad-tipped exhaust to reside out back and - judging by previous spy shots and the official video - BMW's trademark fender vents.
BMW kindly requests you to register at M-Power.com for more details and to sign up for an exclusive test drive. The rub: it's only open to "German and Austrian" drivers. Here's hoping that unjust regionalism doesn't extend to sales when the 1 Series M Coupe hit dealers in the second quarter of 2011.
Continue reading Video: BMW teases 1 Series M Coupe
Video: BMW teases 1 Series M Coupe originally appeared on Autoblog on Thu, 08 Jul 2010 19:36:00 EST. Please see our terms for use of feeds.
أكثر...
قديم 09-07-2010, 09:00 PM
مراسل مصر موتورز
الموقع: مصر
BMW delivers pair of JDM specials - Mini Savile Row and X6 Performance Unlimited
Filed under: , , , , , ,
Japanese-market Mini Saville Row - Click above for high-res image gallery
Black is the new black, at least when it comes to the special edition Mini Saville Row for the Japanese market. The black-as-deep-space hatch with the black roof is accented by polished chrome 17-inch wheels, gas cap, mirrors and trim outside and in. Privacy glass, bi-xenon headlights, white turn signal lamps and an anthracite headliner have been thrown into the mix as well. There will be 100 made, all with the 1.6-liter four-cylinder and automatic transmissions, costing ¥3,100,000 ($35,028 U.S.). That's a premium of about ¥400,000 ($4,519 U.S.) over the standard Mini.
There will be just 20 examples built of the even more limited edition BMW X6 Performance Unlimited, also for the Japanese market only. Inspired by BMW motorsports, the crossover gets a twin-turbo 3.0-liter six-cylinder with hybrid technology running through an eight-speed automatic transmission. The body receives silver pearl paint, a BMW Performance aero package, 21-inch alloys and a blacked-out grille, the interior gets Dakota leather and brushed aluminum pedals. It retails for a tidy ¥9,450,000 ($106,823 U.S.). You check it out, along with the Mini Saville Row, in the high-res galleries below.
[Source: BMW]
BMW delivers pair of JDM specials - Mini Savile Row and X6 Performance Unlimited originally appeared on Autoblog on Fri, 09 Jul 2010 13:58:00 EST. Please see our terms for use of feeds.
أكثر...
الساعة الآن 08:04 PM.
