قديم 24-10-2012, 10:08 AM
افتراضي رد: for my dear friend samirayad heLp us to do that in our cars!!
screamseko
:C HUBBY~36:
قديم 25-10-2012, 08:21 PM
الصورة الرمزية محمد فيصل
من انا؟: العبد الفقير لله
الموقع: الاسكندريه
قديم 28-10-2012, 11:15 AM
المشاركة الأصلية كتبت بواسطة محمد فيصل مشاهدة المشاركة
The entire concept of running your car on water is based on bad science. The idea is to use electricity from the car's alternator to electrolyze water into HHO, a mixture of pure hydrogen and oxygen. This mix is fed into the intake air, where it is burned along with gasoline, thereby increasing your fuel economy anywhere from 15 to 100 percent--depending on which website you're visiting. Believe the hype, and those 1 to 2 liters of HHO streamed into the engine will double the fuel economy, clean the engine out, and maybe even grow hair. Plenty of these budget sites even claim their devices are efficient enough for a version that would run a car entirely on water--no gasoline at all.
that the HHO injection is only an enabler for other devices and changes. The fuel savings doesn't come from the energy contained in the hydrogen as it's burned, which is what I've asserted all along was implausible. Giroux sells a system of modifications that disables the engine management's computer and makes the engine run extremely lean--as lean as 20:1. That's far from the normal 14.7:1. The hydrogen is necessary to let the ultralean mix burn completely, he claims. There's also a heater for the fuel to promote complete vaporization, and some additives for the fuel and oil to complete his system.
http://www.youtube.com/user/savegass...e=results_main
Giant 310 Plate HHO Dry Cell - 50+ LPM
here's an idea try a water spray in the air intake while running just hho the water will provide the expansion needed for conventional engines
gasoline has alot more expansion but hho is hotter
This video shows the effect 10+ lpm of hydroxy has on afr in a 350 chevrolet. Efi vehicles go to a default mode at wot to make afr rich
قديم 28-10-2012, 01:28 PM
Smile رد: for my dear friend samirayad heLp us to do that in our cars!!
mhamdy75
قديم 29-10-2012, 06:02 PM
الصورة الرمزية nktis
nktis nktis غير متواجد حالياً
من انا؟: عبد من عباد الله
التخصص العملى: صيدلي
هواياتي: الصيد والتربيه
الموقع: هنا
admire
وأتت ملائكة النعيم كما روت*
روحي بطون أكفها خضراء*
صعدت بروحك والعبير يحفها*
والنور ترسم دربه الأنواء*
شرقت حشاشات النحيب وأينعت*
أكبادنا فبكاؤنا إيماء*
مجانية, aqua, المهتز, البترول, التحمير, البحر, البنزين, السولار, القلية و, انجكشن, بانتون, تسلا, تكنولوجيا, ديزل, دينامو, رشاشات, زيت, شحن, سولار, فولفو, فورد, نيكوﻻ, طاقة, كربراتير
كيف تختار نوع البنزين لسيارتك Engineer Ebrahim BMW News Archive 1 23-04-2013 06:35 PM
الساعة الآن 10:42 PM.
