قديم 24-01-2012, 11:03 PM
افتراضي رد: كل واحد بيغير زيت عربيتو يغيرو نوعة اية وعامل اية الزيت معاة
المشاركة الأصلية كتبت بواسطة محمود زيزوو مشاهدة المشاركة
بس يا mr_astra دلوقتى الزيت دة بتاع العربيات النقل هل ينفع للعربيات البنزين بصراحة انا اول مرة اعرف الموضوع دة بس نشوف كدة يا جماعة اللى عندة تجارب مع الزيوت ياريت يقول علشان كلة يستفيد من الموضوع دة اكبر استفادة
: Wkiss5:
قديم 24-01-2012, 11:09 PM
mahmoudeka mahmoudeka غير متواجد حالياً
من انا؟: Eka
التخصص العملى: Accountant
هواياتي: Driver
الموقع: Cario
mahmoudeka has a spectacular aura aboutmahmoudeka has a spectacular aura about
قديم 24-01-2012, 11:32 PM
بس فيه ملحوظة
Mobil Delvac MX 15W-40
High Performance Diesel Engine Oil
Product Description
Mobil Delvac MX 15W-40 is a high performance diesel engine oil that helps extend engine life in the most severe on and off highway applications. The advanced chemistry of these products delivers exceptional performance in both modern, high-output engines including those with Exhaust Gas Recirculation (EGR), as well as older engines operating on either low or high sulfur fuels. As a result, Mobil Delvac MX 15W-40 meets or exceeds the API CI-4 PLUS service category and ACEA E7 industry specifications.
Mobil Delvac MX 15W-40 is recommended by ExxonMobil for use in a wide range of heavy duty applications and operating environments found in the trucking, mining, construction, quarrying, marine and agricultural industries. These products will provide outstanding protection in the most demanding diesel engines of Caterpillar, Cummins, Detroit Diesel, Mack, Mercedes Benz, Navistar, Volvo, and others. Mobil Delvac MX 15W-40 also meets or exceeds the API SL specification for gasoline engines and mixed fleets.
The outstanding performance reserve of Mobil Delvac MX 15W-40 is the result of extensive cooperative development work with major Original Equipment Manufacturers (OEMs) and advanced additive chemistry with patented Trimer technology. These enhancements assure excellent control of oil thickening due to soot build-up and exposure to higher temperatures and provide outstanding resistance to oxidation, corrosion, wear, and high temperature deposits.
http://www.mobil.us/USA-English/Lube...MX_15W-40.aspx
قديم 25-01-2012, 12:15 AM
الصورة الرمزية M.TONSY
M.TONSY M.TONSY غير متواجد حالياً
من انا؟: بتعامل بطيبة وحسن نية مع البشر واحتسبه عند الله
التخصص العملى: Administration Development Specialist
هواياتي: السيارات والسباحة والاسلحة وبحب الشغل اليدوى
الموقع: قاهرة مصر اغلى وطن
M.TONSY has a reputation beyond reputeM.TONSY has a reputation beyond reputeM.TONSY has a reputation beyond reputeM.TONSY has a reputation beyond reputeM.TONSY has a reputation beyond reputeM.TONSY has a reputation beyond reputeM.TONSY has a reputation beyond reputeM.TONSY has a reputation beyond reputeM.TONSY has a reputation beyond reputeM.TONSY has a reputation beyond reputeM.TONSY has a reputation beyond repute
انا بحط زيت فيسكو2000 ب97ج وبصراحة ممتاز انا الاول كنت بحط شيل هيلكس الاصفر ولا حاجة جنب الفيسكو والزيت فيه تقنية اسمها درع الحماية بتحافظ على عدم تآكل اجزاء المحرك وبتعمل على تنظيف المحرك من نواتج الاحتراق والشركة المنتجة للزيت انجليزية ومعبأ فى الامارات ومبترشم بالبلاستيك يعنى مفيهوش غش ولا تلاعب
وبالنسب لملاحظاتى عليه الزيت لونه احمر وبعد 1000ك تقريبا بيتحول للون الاصفر وبعد 4500ك لونه اصفر نقى هو المفروض بيقعد 5000ك ولكنى حاسس انه بيقعد اكتر من كدة ولكن ان شاء الله الغيار الجاى هحط فيسكو 3000 بيقعد 10000ك ب120ج
لا اله الا الله ..... محمد رسول الله
سبحان الله وبحمده عدد خلقه ورضا نفسه وزنة عرشه ومداد كلماته
وصلى اللهم على سيدنا محمد وعلى آله وصحبه وسلم
قديم 25-01-2012, 01:23 AM
المشاركة الأصلية كتبت بواسطة khaabas مشاهدة المشاركة
بس فيه ملحوظة
Product Description
وده كمان زيت فالفالينا ممتاز للفتيس العادى المانيوال والكارونة فى الدفع والجر الخلفى !!!
التجربة خير برهان !!!!!!!!!!!!!
والفتيس المانيوال اللى فيه ونه او نتشة او زعقة فى الغيارات بنفضى الزيت القديم خا لص ونحط علبة ابرو ونزود زيت فالفالينا موبيل وكزلك نفس التعامل مع الكارونة التى بها زنة او
ونة او جعرة!!! والله المستعان فهو نعم المولى ونعم
النصير !!
كل ما كان صوت الونة او الجعرة فى الفتيس عالى بنستعمل زيت لزوجة
عالية وزيت موبيل فالفالينا ياءتى فى جركن 4 لتر مقفول اوعى تغير على
طرمبة الزيت اللى فى محطة البنزين
لانهم دايما بيكونوا حطين فيها زيت 90 فالفالينا وده زيت تروس زى قلته
وعديم الفائدة !!
Mobilube 85W-140
Mobilube 85W-160
Mobilube 85W-130
High performance, heavy duty gear oil
• Formulated from high quality base oils and an advanced additive system
• Outstanding protection against wear and scoring
• Provides excellent performance
: Wkiss5:
الساعة الآن 05:16 PM.
