قديم 08-05-2011, 12:07 AM
الصورة الرمزية MmFFoR
افتراضي رد: ممكن المقارنه بين الباسات وbmw 316 موديل 2010
Volkswagen Passat Variant TSI EcoFuel is a 5-seat, 5-door station wagon (estate, shooting brake) that has front wheel drive (FWD). This model has been initiated in 2010. The automobile has the following dimensions: width - 1820.00 mm, length - 4774.00 mm, height - 1517.00 mm. Additionally, its front and rear track are 1552.00 mm and 1551.00 mm respectively and its wheelbase is 2709.00 mm. 1558 kg is the curb weight. The Volkswagen Passat Variant TSI EcoFuel engine is turbo/surpercharged, 4-cylinder with 2 valves per cylinder and has a single overhead camshaft (SOHC) and engine displacement of 1390 cc. It is located in the front of the vehicle and its alignment is transverse. Its cylinders are inline-arranged. The piston stroke length is 75.60 mm and the cylinder diameter is 76.50 mm. The compression ratio is 10.00:1. The maximum torque and maximum power delivered by the engine are 220 Nm at 1500-4500 rpm and 110 kW / 150 ps at 5500 rpm respectively. The fuel system of this model is direct petrol injection. A wet sump oiling system of the engine is used for lubricating its parts. The vehicle can accelerate from 0 to 100 km/h for 9.90 s. The automobile can make a quarter mile and one kilometer for 17.20 s and 31.30 s respectively. This model has a drag area of 0.6870 m2, its frontal area being 2.2900 m2 and drag coefficient - 0.3. The Volkswagen Passat Variant TSI EcoFuel has a 6-speed manual transmission. 0.73:1 is the top gear ratio. Its final drive ratio is 3.65:1. The urban fuel consumption of this automobile is 6.1 l/100 km, the extra urban fuel consumption is 3.6 l/100 km and the combined is 4.6 l/100 km. 70.0 l is the volume of the fuel tank. The CO2 emission rating is 124 g/km. The vehicle's steering box is variable power assisted rack and pinion type. The front wheels size is 6.5J x 16. The size of the rear wheels is 6.5J x 16. The type/size of tyres in the front is 205/55 R 16 H. The size/type of tyres in the rear is 205/55 R 16 H. The front brakes are set up with ventilated disks. The rear brakes are provided with disks, servo assistance, anti-lock braking system (ABS). The front brakes diameter is 312.00 mm and the rear brakes one is 282.00 mm.
قديم 08-05-2011, 12:13 AM
ارتفاع البي ام height - 1421.00 mm
ارتفاع الباسات height - 1517.00 mm
طول البي ام length - 4520.00 mm
طول الباسات length - 4774.00 mm
عرض البي ام width - 1817.00
عرض الباسات width - 1820.00 mm
قاعدة عجلات البي ام ( لها علاقة باتساع الصالون ) 2760.00 mm
قاعدة عجلات الباسات 2709.00 mm
الخلاصة : السيارتين فئة واحدة في الحجم و المحرك و السعر
التوصية : - البي ام اكثر انخفاضا و بالتالي ثباتا افضل في الجودة و الشكل و اسهل في الصيانة و توافر قطع الغيار و اوسع في قاعدة العجلات و بالتالي اتساع الصالون
ارشح البي ام و الله الموفق
قديم 08-05-2011, 12:16 AM
ابعاد الفئة الخامسة
width - 1860.00 mm,
length - 5039.00 mm
, height - 1471.00 mm.
, the length of the wheelbase of this model is 3108.00 mm
قديم 08-05-2011, 11:39 AM
bolbol_675 bolbol_675 غير متواجد حالياً
التخصص العملى: مسئول IT بشركة
هواياتي: القراءة و السيارات
الموقع: الكويت
bolbol_675 has a spectacular aura aboutbolbol_675 has a spectacular aura aboutbolbol_675 has a spectacular aura about
المشاركة الأصلية كتبت بواسطة كار كير فورميلا1 مشاهدة المشاركة
مينفعش نقارن الباسات بالفائه الخامسه
علشان فئه الخامسه اغلي بكتير
بس لما نقارنه فئه ثالثه بالباسات
هنلقي سعرهم متقارب
المقارنه الصح لازم تكون في الحجم و الامكانيات .... ده لو هاتقارن زي أي مقارنه عالميه زي اللي بتحصل في Top Gear مثلا
لكن لو هاتقارن بالسعر ده موضوع تاني
بس حتى لو في السعر دي مقارنه غير متكافئه لان الفولكس حاجه و البي ام حاجه تانيه خالص
(((مع احترامي لرأيك طبعاً )))
قديم 08-05-2011, 05:37 PM
المقارنة مع الباسات تقابلها البي ام الفئة الثالثة فعلا في الحجم و السعر و الاداء و الكماليات - مفيش خطأ في المقارة لانالفئة الخامسة اكبر من الباسات و تقارن بالاودي 6 بينما الباسات نفس قاعدة عجلات الاودي 4 المقابلة للفئة الثالثة
الساعة الآن 06:12 PM.
