قديم 19-03-2014, 11:18 AM
الصورة الرمزية romeoalmansour
التخصص العملى: Engineer
هواياتي: reading and reading
الموقع: cairo
افتراضي رد: عندي مشكلة مع تويوتا يارس فبرجاء الافادة
1- Drivers door open & unlocked. Key out of ignition
2- Insert & remove key 2 times within 5 seconds
3- Close & open drivers door twice within 40 seconds
4- Insert key into ignition & remove
5- Close & open drivers door twice within 40 seconds
6- Insert key into ignition
7- Close the door
8- Turn ignition switch from "LOCK" to "ON" & back to "LOCK"
- ONCE for ADD mode
- TWICE for REWRITE mode
9- Remove the key from ignition
10- To confirm your mode selection, the power locks will now cycle "lock" to "unlock" a
number of times corresponding to your key cycles in step 8
11- Within 40 seconds of confirmation
- Press both transmitter Lock & Ulock buttons simultaneously
- Within 3 seconds press transmitter Lock button for more than 1 second
- If successful, the power locks will cycle once (twice indicates transmitter problems)
- Repeat step 11 for additional remotes
12- Open door to exit programing
الله العظيم أعلي وأعلم
قديم 19-03-2014, 11:57 AM
الموقع: cairo
Enter your Toyota Yaris with your keyless remote and ignition key in hand, and close all the doors except the driver's door. Leave the driver's door unlocked
Insert your key into the ignition and remove it two times in quick order, then close and open the driver's door twice
Insert and remove the key into and from the ignition once more, then close and open the driver's door two more times
Insert the key into the ignition again; close the door, and turn the key once from the "Lock" position to the "On" position and back
Remove the key from the ignition and wait for the locks to cycle to confirm the beginning of the programming sequence
Press and hold the lock and unlock buttons on your remote for three seconds, release and hold the lock button on your remote for one second. Wait for the locks to again cycle to indicate that the programming was successful
Repeat Step 6 (last step) with any additional remotes, then open the door to exit the programming sequence.
قديم 19-03-2014, 10:36 PM
sam66 sam66 غير متواجد حالياً
sam66 is on a distinguished road
بارك الله فيك يا باشا والله تاعبكم معايا بس خليني احكيلك انا انهاردة كنت عند الميكانيكي بتاعي وفاجئني بموضوع غريب في حكاية الريموت قالي افصل كابلات البطارية لمدة ساعة وركبها مرة تانية هتلاقي المفتاح اتبرمج بس لسة ما جربتش وقالي علي موضوع تاني ان العربية يادوب عاملة 50 الف كيلو ومن المستحيل يكون الفلتر الي في الفتيس هو اللي خانق العربية بس في ملحوظة انا لما غيرت زيت الفتيس اخد حوالي اثنين كيلو ونص والميكانيكي قالي دا لما يبقي فاضي بياخد حوالي ثمانية كيلو هل الكلام ده صحيح ولاايه ؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟ ؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟
تويوتا ياريس
الساعة الآن 05:37 AM.
