قديم 03-08-2011, 02:31 PM
essamenen essamenen غير متواجد حالياً
essamenen has a reputation beyond reputeessamenen has a reputation beyond reputeessamenen has a reputation beyond reputeessamenen has a reputation beyond reputeessamenen has a reputation beyond reputeessamenen has a reputation beyond reputeessamenen has a reputation beyond reputeessamenen has a reputation beyond reputeessamenen has a reputation beyond reputeessamenen has a reputation beyond reputeessamenen has a reputation beyond repute
افتراضي رد: مقارنة بين فيات ريجاتا وفيات 131
رد: ايهما افضل ريجاتا ام 131
<HR style="BACKGROUND-COLOR: #7ccefd; COLOR: #7ccefd" SIZE=1><!-- / icon and title --><!-- message -->على فكره لازم تعرف انتى عاوز ايه من العربيه علشان تشتريها
1- المحرك هما نفس عائله المحرك حتى انه نفس الكفائه (محرك الريجاتا هونفسه محرك 131 الالمنيوم المائل 1600 )
مواصفات المحرك
131
<TABLE border=0 cellSpacing=3 cellPadding=0 width="100%" frame=void align=top height=*><TBODY><TR><TD>Cylinders alignment:
</TD><TD>Line 4
</TD></TR><TR><TD>Displacement:
</TD><TD>1585 cm3 / 96.7 cui
</TD></TR><TR><TD>Bore:
</TD><TD>84 mm / 3.31 in
</TD></TR><TR><TD>Stroke:
</TD><TD>71.5 mm / 2.81 in
</TD></TR><TR><TD>Compression ratio:
</TD><TD>9.1 : 1
</TD></TR><TR><TD>Power net:
</TD><TD>62.5 kW / 85 PS / 84 hp (DIN)
</TD></TR><TR><TD>
</TD><TD>/ 5600
</TD></TR><TR><TD>Torque:
</TD><TD>125 Nm / 92 ft-lb
</TD></TR><TR><TD>
</TD><TD>/ 3000
</TD></TR><TR><TD>الريجاتا
</TD><TD>Line 4
</TD><TD>9 : 1
</TD><TD>60 kW / 82 PS / 80 hp (DIN)
</TD></TR><TR><TD>
</TD><TD>/ 5700
</TD><TD>124 Nm / 91 ft-lb
</TD></TR><TR><TD>
</TD><TD>/ 3000
</TD></TR><TR><TD>Power gross:
</TD></TR></TBODY></TABLE>
</TD><TD>
</TD></TR><TR><TD>
</TD><TD>
</TD></TR><TR><TD></TD><TD>
</TD></TR><TR><TD>
</TD><TD>
2- الات الجر
131 خلفى الريجاتا امامى 131 تكسب لانها جر خلفى
الاتساع والابعاد
131
<TABLE border=0 cellSpacing=3 cellPadding=0 width="100%" frame=void align=top height=*><TBODY><TR><TD>Length:
</TD><TD>4264 mm / 167.9 in
</TD></TR><TR><TD>Width:
</TD><TD>1645 mm / 64.8 in
</TD></TR><TR><TD>Height:
</TD><TD>1410 mm / 55.5 in
</TD></TR><TR><TD>Wheelbase:
</TD><TD>2490 mm / 98 in
</TD></TR><TR><TD>Front track:
</TD><TD>1386 mm / 54.6 in
</TD></TR><TR><TD>Rear track:
</TD><TD>1327 mm / 52.2 in
</TD></TR><TR><TD>Ground clearance:
</TD><TD>
</TD></TR><TR><TD>Fuel:
</TD><TD>50 liter / 13.2 U.S. gal / 11 imp. gal
</TD></TR><TR><TD>Turning circle btw. walls:
</TD><TD>10.3 m / 33.8 ft
الريجاتا
</TD><TD>4260 mm / 167.7 in
</TD><TD>1650 mm / 65 in
</TD><TD>1412 mm / 55.6 in
</TD><TD>2455 mm / 96.7 in
</TD><TD>1403 mm / 55.2 in
</TD><TD>1389 mm / 54.7 in
</TD><TD>
</TD><TD>55 liter / 14.5 U.S. gal / 12.1 imp. gal
</TD><TD>11 m / 36.1 ft
</TD></TR><TR><TD>Turning circle btw. curbs:
مواصفات الجيربوكس
131
<TABLE border=0 cellSpacing=3 cellPadding=0 width="100%" frame=void align=top height=*><TBODY><TR><TD>Gearbox:
</TD><TD>
</TD></TR><TR><TD>Transmission type:
</TD><TD>manual
</TD></TR><TR><TD>
</TD><TD>
</TD></TR><TR><TD>
</TD><TD>
</TD></TR><TR><TD>Number of gears:
</TD><TD>5
</TD></TR><TR><TD>Gear ratios (overall):
</TD><TD>
</TD></TR><TR><TD>I
</TD><TD>3.612 (14.09)
</TD></TR><TR><TD>II
</TD><TD>2.045 (7.98)
</TD></TR><TR><TD>III
</TD><TD>1.357 (5.29)
</TD></TR><TR><TD>IV
</TD><TD>1 (3.9)
</TD></TR><TR><TD>V
</TD><TD>0.834 (3.25)
الرجاتا
</TD><TD>
</TD><TD>manual
</TD></TR><TR><TD>
</TD><TD>
</TD></TR><TR><TD>
</TD><TD>
</TD><TD>5
</TD><TD>
</TD></TR><TR><TD>I
</TD><TD>3.909 (14.03)
</TD><TD>2.267 (8.13)
</TD><TD>1.44 (5.17)
</TD><TD>1.029 (3.69)
</TD></TR><TR><TD>V
</TD><TD>0.824 (2.96)
-بالنسبه للصاج
131 صاجها اقوى من الريجاتا لان الريجاتا بتمشى فيها الباروما
-سعر قطع الغيار تقريبا نفس السعر والتوفر
-الشكل العام من الخارج دى مسئله ذوق وقبول
-من الداخل والطبلو الريجاتا طبعا
شوف انتى عاوز ايه بس فى نقطه ممكن تجيب مرسيدس وتكرهك فى العربيات كلها وممكن تجيب زستافا وتعجبك
حسب حاله العربيه ونظافتها نصيحه جيب الى حالتها انظف بس الاثنين نفس المستوى
قديم 04-08-2011, 01:36 PM
zeyada2002 zeyada2002 غير متواجد حالياً
zeyada2002 is on a distinguished road
المشاركة الأصلية كتبت بواسطة essamenen مشاهدة المشاركة
<hr style="background-color: rgb(124, 206, 253); color: rgb(124, 206, 253);" size="1"><!-- / icon and title --><!-- message -->على فكره لازم تعرف انتى عاوز ايه من العربيه علشان تشتريها
مواصفات المحرك
131
<table align="top" border="0" cellpadding="0" cellspacing="3" frame="void" height="*" width="100%"><tbody><tr>< td>Cylinders alignment:
</td><td>Line 4
</td></tr><tr><td>Displacement:
</td><td>1585 cm3 / 96.7 cui
</td></tr><tr><td>Bore:
</td><td>84 mm / 3.31 in
</td></tr><tr><td>Stroke:
</td><td>71.5 mm / 2.81 in
</td></tr><tr><td>Compression ratio:
</td><td>9.1 : 1
</td></tr><tr><td>Power net:
</td><td>62.5 kW / 85 PS / 84 hp (DIN)
</td></tr><tr><td>
</td><td>/ 5600
</td></tr><tr><td>Torque:
</td><td>125 Nm / 92 ft-lb
</td></tr><tr><td>
</td><td>/ 3000
</td></tr><tr><td>الريجاتا
</td><td>Line 4
</td><td>9 : 1
</td><td>60 kW / 82 PS / 80 hp (DIN)
</td></tr><tr><td>
</td><td>/ 5700
</td><td>124 Nm / 91 ft-lb
</td></tr><tr><td>
</td><td>/ 3000
</td></tr><tr><td>Power gross:
</td></tr></tbody></table>
</td><td>
</td></tr><tr><td>
</td><td>
</td></tr><tr><td>
</td><td>
</td></tr><tr><td>
</td><td>
</td></tr><tr><td>
</td><td>
2- الات الجر
الاتساع والابعاد
131
<table align="top" border="0" cellpadding="0" cellspacing="3" frame="void" height="*" width="100%"><tbody><tr>< td>Length:
</td><td>4264 mm / 167.9 in
</td></tr><tr><td>Width:
</td><td>1645 mm / 64.8 in
</td></tr><tr><td>Height:
</td><td>1410 mm / 55.5 in
</td></tr><tr><td>Wheelbase:
</td><td>2490 mm / 98 in
</td></tr><tr><td>Front track:
</td><td>1386 mm / 54.6 in
</td></tr><tr><td>Rear track:
</td><td>1327 mm / 52.2 in
</td></tr><tr><td>Ground clearance:
</td><td>
</td></tr><tr><td>Fuel:
</td><td>50 liter / 13.2 U.S. gal / 11 imp. gal
</td></tr><tr><td>Turning circle btw. walls:
</td><td>10.3 m / 33.8 ft
الريجاتا
</td><td>4260 mm / 167.7 in
</td><td>1650 mm / 65 in
</td><td>1412 mm / 55.6 in
</td><td>2455 mm / 96.7 in
</td><td>1403 mm / 55.2 in
</td><td>1389 mm / 54.7 in
</td><td>
</td><td>55 liter / 14.5 U.S. gal / 12.1 imp. gal
</td><td>11 m / 36.1 ft
</td></tr><tr><td>Turning circle btw. curbs:
مواصفات الجيربوكس
131
<table align="top" border="0" cellpadding="0" cellspacing="3" frame="void" height="*" width="100%"><tbody><tr>< td>Gearbox:
</td><td>
</td></tr><tr><td>Transmission type:
</td><td>manual
</td></tr><tr><td>
</td><td>
</td></tr><tr><td>
</td><td>
</td></tr><tr><td>Number of gears:
</td><td>5
</td></tr><tr><td>Gear ratios (overall):
</td><td>
</td></tr><tr><td>I
</td><td>3.612 (14.09)
</td></tr><tr><td>II
</td><td>2.045 (7.98)
</td></tr><tr><td>III
</td><td>1.357 (5.29)
</td></tr><tr><td>IV
</td><td>1 (3.9)
</td></tr><tr><td>V
</td><td>0.834 (3.25)
الرجاتا
</td><td>
</td><td>manual
</td></tr><tr><td>
</td><td>
</td></tr><tr><td>
</td><td>
</td><td>5
</td><td>
</td></tr><tr><td>I
</td><td>3.909 (14.03)
</td><td>2.267 (8.13)
</td><td>1.44 (5.17)
</td><td>1.029 (3.69)
</td></tr><tr><td>V
</td><td>0.824 (2.96)
-بالنسبه للصاج
شكرا لك وكلام حضرتك مقنع جدا
الساعة الآن 04:06 PM.
