قديم 06-01-2010, 07:20 PM
مراسل مصر موتورز
من انا؟: إدارة مصرموتورز
الموقع: مصر
Report: Details on 2011 BMW M1 trickle out
Filed under: , , ,
BMW 1 Series Tii Concept - Click above for high-res image gallery
A BMW 1 Series Coupe, tweaked by the company's M-Technik division, is reportedly under development for UK release in mid-2011. Destined to slot beneath the M3 Coupe, the smaller 1 Series Coupe is said to feature a modified twin-turbocharged six-cylinder packing 350 horsepower. The aluminum engine will be mated to a standard six-speed dual-clutch gearbox with an electronically-controlled rear M differential. With a curb weight of just over 3,300 pounds and easily making more than 310 lb-ft of torque, the newest M-car will breeze past 60 mph in well under five seconds without breaking a sweat (for comparison's sake, BMW claims the 135i takes 5.2 seconds but publications like Car and Driver have hit 60 mph in the 4.7-second range)
The 1 Series Motorsport variant will reportedly retain the current car's standard MacPherson struts up front and the multi-link rear configuration, but the division's engineers have fitted firmer springs and dampers (and new bushings) to improve handling. Lightweight 18-inch alloy wheels complete the hardware package. Cosmetically, the so-called "M1" will wear an M division body kit with a new front spoiler, flared wheel arches, larger side sills, a rear spoiler and an aggressive rear valance with four M-signature chrome exhaust tips.
The name is still not finalized. Understandably, BMW is hesitant to quickly slap the "M1" label on the rear decklid as that name originally adorned the company's legendary road supercar in the late 1970s. Destined to become the M division's most affordable model, we really don't care what BMW calls it... just send it to our shores.
[Sources: Autocar; Car and Driver]
Report: Details on 2011 BMW M1 trickle out originally appeared on Autoblog on Wed, 06 Jan 2010 11:00:00 EST. Please see our terms for use of feeds.
أكثر...
قديم 09-01-2010, 05:40 AM
مراسل مصر موتورز
الموقع: مصر
Spy Shots: BMW 3 Series Gran Turismo caught swirling around?
Filed under: , , , , , ,
If you love the idea of the 5 Series Gran Turismo but don't want a vehicle quite that large, BMW's got something baking in the oven that you may very well be interested in: a 3 Series Gran Turismo. Just like its larger sibling, this wagon that's masquerading as anything other than a wagon will sport a fastback-like rear roof design that covers up a larger cargo hold than the standard 3's trunk.
It appears that the upcoming 3 Series Gran Turismo will be both longer and wider than the current 3, and that size advantage may carry over to the rest of the 3 Series line as well. Expect a predominantly aluminum chassis underneath the slinky new bodywork to help keep weight from escalating out of control.
BMW has made no mention of when the 3 Series GT might hit the market, but if it makes an appearance before the expected sedan, coupe and wagon versions of the next 3 - as was the case with the latest BMW 5 Series - we might see the fastback wagon sometime in 2012.
[Source: Autocar]
Spy Shots: BMW 3 Series Gran Turismo caught swirling around? originally appeared on Autoblog on Fri, 08 Jan 2010 09:30:00 EST. Please see our terms for use of feeds.
Read | Permalink | Email this | Comments
أكثر...
مراسل مصر موتورز
الموقع: مصر
Report: BMW working on twin-engine hybrid powertrain?
Filed under: , ,
BMW is knee-deep in hybrid technology these days, having both mild hybrids and sophisticated full two-mode drivetrains in production. Apparently, there's work underway on a radical twin-engine system as well, proof of which can be seen by perusing this patent application.
Unlike any hybrid powertrain currently on the road, one of the engines in BMW's split-hybrid technology remains completely dormant unless more power is needed than the first engine and electric motor combination can provide. The patent application specifies that each internal combustion engine would have two cylinders - a configuration that BMW has a great deal of experience in on the motorcycle side.
Like BMW's current hybrid systems, the electric motor would be integrated into the transmission, and it seems that the two gasoline-fed engines are mounted together as one unit. We have no idea if the German automaker has plans to put such a system into production, but it's obvious that it's at least considering the possibility. Stay tuned.
[Source: BimmerFile]
Report: BMW working on twin-engine hybrid powertrain? originally appeared on Autoblog on Fri, 08 Jan 2010 17:29:00 EST. Please see our terms for use of feeds.
أكثر...
قديم 10-01-2010, 10:20 PM
مراسل مصر موتورز
الموقع: مصر
Report: As it turns out, BMW's Roundel logo isn't born from jets... er, planes
Filed under: , ,
The source of the confusion?
It turns out that not even BMW's spokespeople know that its Roundel emblem wasn't inspired by a spinning propeller. It's a common misconception, one that's finally been cleared up by BMW spokesman Tom Plucinsky, who explained that the company used to think its recognizable logo was tied to its aeronautical history. Plucinsky's colleague Dave Buchko had initially told the The New York Times that the logo was intended as a stylized image of a spinning propeller before being corrected by Anne Schmidt-Possiwal of the BMW Museum in Munich. To his credit, Buchko did correct the error himself once the real story came to light.
So what's the real origin? It turns out the blue-and-white logo was used in a 1929 ad that placed roundels in the rotating propellers of an airplane. It's easy to see where the confusion came from. The blue and white quadrants at the heart of the logo are actually intended to signify the state colors of Bavaria, and this isn't the first time the logo's origin has been examined in detail - historians have traced the logo's evolution from the Rapp Motorenwerke all the way through today.
[Source: The New York Times | Photo: BMWClub.ro]
Report: As it turns out, BMW's Roundel logo isn't born from jets... er, planes originally appeared on Autoblog on Sun, 10 Jan 2010 13:55:00 EST. Please see our terms for use of feeds.
أكثر...
قديم 12-01-2010, 12:40 AM
مراسل مصر موتورز
الموقع: مصر
Detroit 2010: BMW ActiveE concept is all charged up and ready to go
BMW ActiveE concept - Click above for high-res image gallery
At first glance, the BMW ActiveE concept is little more than a 1 Series with a questionable paint job. Seriously, the ActiveE looks like it's been sniffing blue paint. However, should you choose to look more closely, you will notice it's missing tailpipes. Also, someone ripped off the fuel-filler door. There's a blue light on the back of the antenna, too. Why? Good question.
The ActiveE concept is all electric. Similar to the Mini E electric car, the ActiveE is powered by a rear-mounted electric motor that stumps up 170 horsepower and 184 pound-feet of torque, which may even be decent enough to lug the notoriously overweight 1 Series around town. BMW claims 0-60 in less than nine seconds. The juice is stored in a chained-together group of laptop batteries - quite similar to how the Tesla Roadster is set up.
Like the Mini E, BMW is planning on putting the production ActiveE into the hands of consumers who want one. Fleets, too. No word whatsoever on pricing, but expect a lease. For lots more information, read the press release after the jump.
Live Photos by Chris Paukert / Copyright (C)2010 Weblogs, Inc.
[Source: BMW]
Continue reading Detroit 2010: BMW ActiveE concept is all charged up and ready to go
Detroit 2010: BMW ActiveE concept is all charged up and ready to go originally appeared on Autoblog on Mon, 11 Jan 2010 16:28:00 EST. Please see our terms for use of feeds.
أكثر...
الساعة الآن 12:53 PM.
