قديم 12-03-2010, 02:56 PM
atgps atgps غير متواجد حالياً
افتراضي رد: كام سعر كابل توصيل العربيه بالابتوب
المشاركة الأصلية كتبت بواسطة casper348 مشاهدة المشاركة
هو اسمو تقريبا Obd
الى عنده معلومات ياريت يفيدنى
سيارات الفولكس فاجن جروب يعمل معها كابلات الـ VAG
وعندى VAG COM 812.4
ومواصفاته
Detailed Description
HEX USB CAN VAG-COM for 812
Compatible with the newest cars which require a direct CAN connection for diagnostics including all Golf-5 platform cars and latest Audi A3, A6 and A8,Q7,etc.
Protocol timing indistinguishable from a real VAG/VAS tool. Works reliably even with "difficult" control modules such as the 1991-1994 1Z Audi TDIs and the 1993-1994 Audi 2.6L with Hella ECU. Built-In VAG-Saver functionality -- instantly alerts the user if either the K/K1 line or the L/K2 line is shorted to Ground or Vbatt.
Full support for dual-K lines found in "new" (B6/8E chassis Audi A4 and 2002+ Audi A6,A8,etc.
1.USB connector plugs into most modern laptops!
2.Compatible with the latest cars which require a direct CAN connection for diagnostics including all
Golf-5 platform cars and latest Audi A3, A6 and A8.
3.Protocol timing indistinguishable from a real VAG/VAS tool. Works reliably even with "difficult" control
4.Built-In VAG-Saver functionality -- instantly alerts the user if either the K/K1 line or the L/K2 line is
5.Full support for dual-K lines found in "new" (B6/8E chassis Audi A4 and 2002+ Audi A6 -- no VAS-
6017 required -- no manual switches!
6.Fully backwards compatible with older cars using a single K-line or K plus L.
7.Bi-Color (red/green) status/activity LED
The product description:
OBDII Can USB with the latest cars which require a direct CAN connection for diagnostics including all Golf-5 platform cars and latest Audi A3, A6 and A8,Q7.
The possibility that software is complete is on the xxxxx renewal, function all of, support the car type to 2009.
Diagnostics Type including:
All Golf-5 platform cars (A5 platform) including:
2003+ VW Touran (1T chassis)
2004+ VW Golf (1K chassis)
2004+ VW Caddy (2K chassis)
2004+ Audi A3 (8P chassis)
2004+ Seat Altea (5P chassis)
2004+ Skoda Octavia (1Z chassis)
2005+ Seat Toledo (5P chassis)
2005+ Golf Plus (5M chassis)
2005+ Seat Leon (1P chassis)
2005.5+ Jetta (1K chassis)
2006+ Eos (1F chassis)
2003+ Audi A8 and A8L (D3 platform, 4E chassis)
2005+ Audi A6 (C6 platform, 4F chassis)
2005+ Audi A4 ("B7" platform) (some control modules)
2005.5+ VW Passat (B6 Platform, 3C chassis)
2006+ Audi Q7 (4L chassis)
2007+ Audi R8 (42 chassis)
2007+ Audi TT (8J chassis)
2007+ VW Touareg (7L6 chassis) ("facelift", built after Nov. 30 2006)
2009+ Audi A4 ("B8" platform)
وكذلك عندى USB KKL VAG-COM 409.1
Workable Model
This diagnostic cable is usable for ISO9141 and KWP2000 transmission protocol like used for example by:
Volkswagen
Audi
Skoda
Seat
Reference Data
1
.This cable can not work if your car uses a protocol/bussystem like VPW, PWM or CAN-bus.
2. Terminal K = Bus of communication
3. Terminal L = Ignition for waking up car computing system (ECU: Engine Control Unit)
4. Existed 3 different protocols with same OBD2 connector incl. ISO/KWP, VPW, PMW
5. This K/L Diagnostic interface & cables work on ISO/KWP (Key Word Protocol) launched after 1996 only.
6. Supported also ISO9141 protocol
7.The Cables may work with some versions of the Carsoft, but carsoft used a lot of different interfaces during the different versions and also had some custom interfaces.
اذا رغبت فى تجربة أى منهم للتأكد أنهم يعملوا على سيارتك فمرحبا بك
قديم 12-03-2010, 09:38 PM
casper348 casper348 غير متواجد حالياً
casper348 is on a distinguished road
سعرهم كام ؟؟
قديم 13-03-2010, 12:58 AM
سعرهم كام ؟؟
سعرهم من 800 الى 1300 بس شوف أى واحد حيشتغل مع عربيتك ومتهيألى كلهم يشتغلوا.
قديم 18-03-2011, 12:26 PM
esam19260 esam19260 غير متواجد حالياً
esam19260 is on a distinguished road
الاخ الفاضل
الرجاء ارسال رقم تليفونك حتى نتفق على شراء الكابل (اميل الياهو alaasat)
عصام
قديم 11-12-2011, 07:48 PM
mikovico mikovico غير متواجد حالياً
mikovico is on a distinguished road
الكبلات دي عندي او حد عايز يكلمني 01224675849
نوعه elm327
الساعة الآن 03:55 PM.
