نوبيرا
قديم 08-10-2013, 01:38 PM
الصورة الرمزية romeoalmansour
التخصص العملى: Engineer
هواياتي: reading and reading
الموقع: cairo
افتراضي رد: سؤال بالنسبه للفتيس الأتوماتيك
The Governor
The governor is a clever valve that tells the transmission how fast the car is going. It is connected to the output, so the faster the car moves, the faster the governor spins. Inside the governor is a spring-loaded valve that opens in proportion to how fast the governor is spinning -- the faster the governor spins, the more the valve opens. Fluid from the pump is fed to the governor through the output shaft
The faster the car goes, the more the governor valve opens and the higher the pressure of the fluid it lets through
GOVERNOR
THE GOVERNOR is installed in the automatic transmission. It senses vehicle speed and changes governor pressure to help control gear shifting
الله العظيم أعلي وأعلم
قديم 08-10-2013, 01:47 PM
الموقع: cairo
وموجود في الفتايس دي
TH-350, TH-400, and 700-R4 automatic transmissions
قديم 08-10-2013, 01:49 PM
الموقع: cairo
Think of the governor as a hydraulic speedometer, which tells the transmission when to shift up based on vehicle speed. The governor turns in direct relation to the output shaft rotation, and therefore vehicle speed. Inside the governor is a valve that opens and closes to "govern" the up-shifts
قديم 08-10-2013, 01:50 PM
الموقع: cairo
هي النوبيرة اللي معاك موديل سنه كام
قديم 08-10-2013, 01:52 PM
الموقع: cairo
There are two sets of rotating weights in the governor. The heavier, outer weights act at low vehicle speed and the lighter inner weights take over at higher speeds, especially during full throttle conditions. Centrifugal force acting upon the weights controls the opening and closing of the governor valve itself. The valve controls governor pressure delivery, which in turn controls upshifts
الساعة الآن 02:07 PM.
