قديم 05-03-2013, 04:38 PM
افتراضي رد: كرادين> صليبة واحدة ناحية الفتيس و صليبتين جهة كل عجلة من العجلات الامامية !اندفاع امامى !
المشاركة الأصلية كتبت بواسطة حمدى مخترع مانيوال بدون د مشاهدة المشاركة
: 0369B3~177:
قديم 13-03-2013, 03:59 AM
للاهمية رد: عملت ورشة ميكانيكا على اد امكانياتى
حمدى مخترع مانيوال بدون دبرياج
( صورة)
قديم 13-03-2013, 03:10 PM
الموقع: محافظة الجيزة
افتراضي رد: عملت ورشة ميكانيكا على اد امكانياتى
: CONGRA~238:
قديم 24-03-2013, 12:36 AM
مميز Delphi now own the De Carbon brand and still supply gas pressurised dampers for the Renault !
حاولت افتح مركز صيانة لاكن امكانياتى لاتسمح فقمت بفتح ورشة على اد امكانياتى واتمنا من الله ان تصبح مركز صيانة وانا فخدمة من يوريد خدمتى من اعضاء الموقع ت 01065229805 ادعولى بالتوفيق :coptic_Thutmosis1S :
monroe do make gas pressurised dampers and these have good reports - these might be the best alternative to DeCarbon.
Kayaba
Gas pressurised ones have good reports.
How Long should dampers last?
the man said and told that he worked on cars still fitted with original dampers after 20 years and 80,000 miles. The original Renault dampers were built to a good specification. But these cars needed new dampers. I'd be happy with 5 to 10 years life as the installation in the Renault is hard on dampers.
for vehicles that occasionally haul heavy loads or tow trailers
  • Large-volume air chamber inflates up to 150 psi with vehicle loaded, and deflates for normal driving.
  • A pair can maintain ride height when up to 1,100 lbs. of additional weight is loaded.
  • Can be adapted for most vehicles equipped with automatic leveling systems.
The Max-Air® shock absorber is ideal for vehicles that haul heavy loads or tow trailers. Designed to maintain level vehicle height, they can be inflated or deflated as needed...from 20 psi to 150 psi with the vehicle loaded.
Packed in pairs that include air line, air fittings, and air fill kit.
  • Contains special modifiers to reduce friction and ensure smooth rod reaction.
  • Better valving range on both the compression and extension cycles of the unit for a smooth comfortable ride.
  • Stronger than traditional metals, enhances durability for long service life.
  • Reduces friction for longer service life. Provides smoother operation during suspension movement.
  • Hardened and precision ground rod for consistent performance and long service life.
  • Resists air leakage.
  • Inflates up to 150 psi with vehicle loaded. Deflates for normal driving.
التعديل الأخير تم بواسطة cars admire ; 24-03-2013 الساعة 12:51 AM
قديم 24-03-2013, 09:39 AM
الصورة الرمزية adham.com
افتراضي رد: Delphi now own the De Carbon brand and still supply gas pressurised dampers for the Renault !
Kayaba
موضوع ممتاز
الساعة الآن 07:31 PM.
