قديم 22-11-2012, 01:08 AM
الصورة الرمزية borio1704
هواياتي: السيارات - الكمبيوتر
افتراضي رد: بنزين 80+نفتالين بلى =90
المشاركة الأصلية كتبت بواسطة محمد شهاب مشاهدة المشاركة
تصحيح صغير
حمض الهيدروكلوريك HCL هو احد الاحماض القوية ولكنه ليس مية النار
مية النار هى حمض الكبريتيك المركز ( المركز) H2SO4
تحياتى للجميع
أقوى الأحماض على وجه الأرض هي كالتالي... وبالترتيب ابتداء من ألأقوى:
حمض النيتريك المركز ، ثم حمض الكبريتيك المركز ، ثم حمض الهيدروكلوريك المركز
وفي اعتقادي كلمة "مية نار" يمكن أن تطلق على أي منها... ربنا يحفظنا منهم جميعا
قديم 22-11-2012, 03:06 AM
الصورة الرمزية Vanditta
Vanditta Vanditta غير متواجد حالياً
الموقع: egypt-cairo
Vanditta has a reputation beyond reputeVanditta has a reputation beyond reputeVanditta has a reputation beyond reputeVanditta has a reputation beyond reputeVanditta has a reputation beyond reputeVanditta has a reputation beyond reputeVanditta has a reputation beyond reputeVanditta has a reputation beyond reputeVanditta has a reputation beyond reputeVanditta has a reputation beyond reputeVanditta has a reputation beyond repute
6.20 Can mothballs increase octane?
The legend of mothballs as an octane enhancer arose well before WWII when
naphthalene was used as the active ingredient. Today, the majority of
mothballs use para-dichlorobenzene in place of naphthalene, so choose
carefully if you wish to experiment :-). There have been some concerns about
the toxicity of para-dichlorobenzene, and naphthalene mothballs have again
become popular. In the 1920s, typical gasoline octane ratings were 40-60
[11], and during the 1930s and 40s, the ratings increased by approximately 20
units as alkyl leads and improved refining processes became widespread [12].
Naphthalene has a blending motor octane number of 90 [52], so the addition of
a significant amount of mothballs could increase the octane, and they were
soluble in gasoline. The amount usually required to appreciably increase the
octane also had some adverse effects. The most obvious was due to the high
melting point ( 80C ), when the fuel evaporated the naphthalene would
precipitate out, blocking jets and filters. With modern gasolines,
naphthalene is more likely to reduce the octane rating, and the amount
required for low octane fuels will also create operational and emissions
problems.
قديم 22-11-2012, 04:52 AM
محمد شهاب محمد شهاب غير متواجد حالياً
محمد شهاب has a reputation beyond reputeمحمد شهاب has a reputation beyond reputeمحمد شهاب has a reputation beyond reputeمحمد شهاب has a reputation beyond reputeمحمد شهاب has a reputation beyond reputeمحمد شهاب has a reputation beyond reputeمحمد شهاب has a reputation beyond reputeمحمد شهاب has a reputation beyond reputeمحمد شهاب has a reputation beyond reputeمحمد شهاب has a reputation beyond reputeمحمد شهاب has a reputation beyond repute
مع احترامى لحضرتك
حمض الكبريتيك فقط هو ما يطلق عليه مية النار وذلك فى صورته المركزة وليست المخففة
وهو ماكان يطلق عليه قديما اسم الزاج الاخضر وذلك فى مراجع الكيمياء القديمة باللغة العربية
لان قوامه كسائل بيكون كثيف مع لون يميل للاخضرار (لون فستقى)
الترتيب اللى انت ذكرته ده يخص درجة ثبات الحمض وليست قوته
شاكر لحضرتك ودمت بود
تحياتى للجميع
قديم 26-11-2012, 03:03 PM
wael890610 wael890610 غير متواجد حالياً
الموقع: الاسماعيليه
wael890610 is a glorious beacon of lightwael890610 is a glorious beacon of lightwael890610 is a glorious beacon of lightwael890610 is a glorious beacon of lightwael890610 is a glorious beacon of lightwael890610 is a glorious beacon of light
يا ريت نعرف ايه هو نوع النفتالين المستخدم (اسمه او بيتجاب من فين) علشان ما نستخدمش حاجه مالهاش لازمه
قديم 26-11-2012, 03:05 PM
الصورة الرمزية JILANCO
JILANCO JILANCO غير متواجد حالياً
من انا؟: مسلم
التخصص العملى: مهندس ميكانيك
هواياتي: دراسة علم الميكانيك
الموقع: الأردن
JILANCO has a brilliant futureJILANCO has a brilliant futureJILANCO has a brilliant futureJILANCO has a brilliant futureJILANCO has a brilliant futureJILANCO has a brilliant futureJILANCO has a brilliant futureJILANCO has a brilliant futureJILANCO has a brilliant futureJILANCO has a brilliant futureJILANCO has a brilliant future
المشاركة الأصلية كتبت بواسطة ماجد شاهين مشاهدة المشاركة
@@قال امامى يوما احد الميكانيكيه ان وضع نفتالين بلى مع ال80 يجعله مثل ال90 لانه يعلى نسبة الاوكتين فى البنزين وكنت متردد فى التجربه حاولت معرفه الموضوع على النت وجدت ان له صدى فى التعليقات والتجارب وملخصها ان السيارات الكاربيراتير وجد افاده فى هذه التجربه اما الحقن فكانت ردود الافعال ليست جيده مثل الكربيراتير ولان سيارتى 131 يعنى كاربيراتير وغالبا ما كنت اخزن البنزين فى جركن قبل وضعه فى التنك لانى اجد به شوائب كثيره حين افرغه فقلت كده كده البنزين 80 ليس نقى فما المانع ان اجرب هذا الموضوعوخاصة انى عرفت النفتالين يذوب فى البنزين ولا يظل صلبا وكنت ما وصلت اليه ان مع كل 10 لتر واحدة نفتلين وفعلا فعلت هذه التجربه فوجدت تغير غير عادى وخاصة انى كنت اشكوا للميكانيكى ان السياره لا تزيد سرعتها عن 140 فللحق وجدت ان عزم السياره اصبح شديد والسحب جميل جدا وصوت الموتور اصبح اهدى من ذى قبل اخبرت بعض زملائى فسخرو منى فى البدايه ثم وجدتهم بعد ايام سعداء جدا ويشكرونى على هذا الموضوع لانهم وجدو سيارتهم مثلما قلت فهل احد عنده جديد فى هذا الموضوع
احذر ثم احذر ثم احذر
الساعة الآن 01:35 PM.
