موضوع مغلق
قديم 26-09-2011, 01:54 AM
للاهمية Outstanding viscosity-temperature behaviour and high chemical resistance
شكرا على التحذير لما يكون الفتيس الخاص بسيارتى جاتكو نيسان يابان ليس CVT ماهو احسن صنف له وشكرا جزيلا
ATF III
Operational area: Hydraulic systems, powersteering systems, torqueconverters, manual and automatic transmissions -- in accordance with the specifications stipulated by vehicle and transmission manufacturers.
Selected base oils and a combination of special additives give this ATF its special quality. Outstanding viscosity-temperature behaviour and high chemical resistance. Excellent wear resistance and effective frictional characteristics. Foam suppression and good air-separation properties. Resistant to ageing, good lubricating properties and corrosion protection.
also ATF DEXRON II DATF Dexron II D is a hydraulic fluid for automatic transmissions and hydraulic clutches for which a Type Dexron D automatic transmission fluid has been specified. ATF Dexron II D also guarantees perfect operation of hydraulic transmissions even under extreme running conditions and when exposed to large temperature fluctuations. Numerous vehicle manufacturers use ATF Dexron IID as a hydraulic fluid for, e.g. power steering systems which have to work under the severest running conditions.
both of them really are a very good
atf
:TH E_PR~18:
  #72
قديم 26-09-2011, 11:35 AM
ليكوى مولى ليكوى مولى غير متواجد حالياً
ليكوى مولى is a splendid one to beholdليكوى مولى is a splendid one to beholdليكوى مولى is a splendid one to beholdليكوى مولى is a splendid one to beholdليكوى مولى is a splendid one to beholdليكوى مولى is a splendid one to beholdليكوى مولى is a splendid one to behold
افتراضي رد: Outstanding viscosity-temperature behaviour and high chemical resistance
ATF III
atf
:TH E_PR~18:
ATF III افضل لسيارة حضرتك
  #73
قديم 26-09-2011, 05:13 PM
الصورة الرمزية titos
titos titos غير متواجد حالياً
التخصص العملى: Build Refrigeration Storge Systems at Assarprofessional
هواياتي: any thing about (cars-computer-tech )
الموقع: damnhour
titos is a jewel in the roughtitos is a jewel in the roughtitos is a jewel in the roughtitos is a jewel in the rough
افتراضي رد: زيت المحركات المانى الصنع LIQUI MOLY
يا رييت مكان و تليفون لو فيه موزع فى الاسكندريه و شكرا
  #74
قديم 26-09-2011, 06:00 PM
المشاركة الأصلية كتبت بواسطة titos مشاهدة المشاركة
موزع اسكندريه 0119768855
اسلام مشهور
  #75
قديم 26-09-2011, 08:11 PM
الصورة الرمزية elmanahry
الاخت reh اذا كان الفتيس الاوتوماتيك يحتاج 5 كيلو زيت وانا ارى عبوة زيت ال LIQUI MOLI زيت الفتيس 500 ml فهل يعنى ذلك هو احتياجى لعبوات عديدة وكم تكلفة غيار الفتيس الاتوماتيك من نوع ال LIQUI MOLI
God grant me the serenity
DR Elmanahry
موضوع مغلق
ليكوى مولى, liqui moly, زيت, زيت محرك, زيت الموتور, زيت فتيس, زيوت السيارات, زيوت زادو, زيوت سيارات, revitalizant, xado
الساعة الآن 10:13 AM.
