موضوع مغلق
قديم 24-09-2011, 02:42 PM
الصورة الرمزية elmanahry
افتراضي رد: زيت المحركات المانى الصنع LIQUI MOLY
CARSADMIRE ايه الروعة والجمال ده ياعبقرى فعلا صفحة مرجعية لمنتجات الشركة واجابة على سؤالى للانسة ريهام تسلم الايادى ياباشا ياعبقرى
God grant me the serenity
DR Elmanahry
  #62
قديم 24-09-2011, 02:44 PM
المشاركة الأصلية كتبت بواسطة ls1090 مشاهدة المشاركة
ممكن العنوان بالقاهره
سيادتك ارجع لاول الموضوع والعنوان مكتوب وشكرا
DR Elmanahry
  #63
قديم 24-09-2011, 03:17 PM
تسلم يا elmanahryباشا ياعبقرى
:Bra vo:
  #64
قديم 25-09-2011, 11:52 AM
مميز the car care portfolio
car wax
Liqui Moly Hard Wax - 600ml
polish, wax, cleaning agents, wheel rim cleaner and leather care.
“With our motor oils and additives we already keep the engine’s interior clean and neat. Now we take care of the car’s exterior”, said Salvatore Coniglio, the export area manager at LIQUI MOLY responsible for UAE. New products were added to the car care portfolio, existing formulations were improved to get even better results, packaging was redesigned to give a better look and package size modified. Altogether there are more than two dozen relaunched or newly introduced products
Liqui-Moly Gloss Spray Wax - 400ml
liqui moly V-BELT SPRAY 400ml
V-BELT SPRAY 400ml
Eliminates V-belt slip and squeals. Keeps them supple and increases their service life. Protects belts and pulleys from wear. Increases efficiency and tractive force. Cares for and protects V-belts. Operational area: For all types of V-belts such as leather, rubber, balata, etc. Not suitable for flat belts.
Liqui-Moly Fabric Protector - 400ml
For optimum protection against the wet. Fabrics remain pliable and breathable. Protects against oil and grease spots and dirt.
Operational area: Universal use for fabric convertible tops, rucksacks, awnings, tents, sports clothing and parasols. Also suitable for products with climatic membranes and suede. They stay pliable and breathable. Protects against spotting.
Liqui-Moly Cockpit Shine - 200ml
Makes dull and weathered plastics look new again. Plastic components regain their original appearance and do not dry out. Stops wearisome rattles and squeaks. Treatment is without greases, is antistatic and dust repellent. Good lubricating effect on rubber and plastic components, impregnates and insulates -- universal application.
Operational area: For rattling and squeaking fascias and sticking safety belts (spray belt on both sides). For all matt plastics such as plastic bumpers and spoiler etc. For general interior care in vehicles.
Liqui-Moly Car Wash Sponge
Specially absorbent and gentle on paint. Long-life and wear resistant.
Operational area: For glass, paint and plastic.
لتنظيف المحرك من الخارج بشكل جاف !!
Liqui-Moly Engine Compartment Cleaner - 400ml
Makes engine compartments brilliantly clean. Dissolves oil and greasy contaminants, tar and brake dust. With high washing and cleaning efficiency. After leaving for a short time to take effect, stubborn residues are easily removed. Does not contain chlorinated hydrocarbons.
Liqui-Moly Lead Subsitute - 250ml
مزيل الرصاص من الوقود بشكل نهائى حتى لا تتضرر الصمامات وقواعدها مما يؤدى لضعف
عام فى تاءدية المحرك !!
High valve seat abrasion. Noticable loss of compression, i.e.: less performance or even engine failure.
Lead substitutes enables an unleaded passenger car handling. Lubricates and protects non-hardened valve seats. Minimizing abrasion, it prevents the engine of damage. For optimum compression.
Liqui Moly Carburetor and Valve Cleaner
منظف كاربراتير وصبابات فى وقت واحد !!
Did my valve cover gaskets and cam chain tensioner gaskets along with spark plugs.
Have been using Lubro Moly 5W40 for as long as i owned the car and everything looked so clean.
Click here to view the original image of 800x533px and 122KB.
Click here to view the original image of 800x533px and 73KB.
يمنع المسامير من الفك من تلقاء نفسها!!!
Bolt lock fluid Liqui Moly high-strength 50g, removable
مانع تسريب زيت المحرك داخليا او خارجيا ومانع تعريق البوجيهات !ديزل وبنزين!
Lubro-Moly Motor Oil Saver (300 ML)
Lubro-Moly Motor Oil Saver (300 ML) Review
Lubro-Moly Motor Oil Saver (300 ML) Feature
  • Reduces oil consumption via the piston rings and valve guides
  • Prevents blue, smoky exhaust fumes
  • Prevents leaks due to leaks at elastomeric seals
  • Regenerates engine seals made of plastic and rubber
  • Prevents pollution of the environment due to oil dripping from the engine
Lubro-Moly Motor Oil Saver (300 ML) Overview
Suitable for all petrol and Diesel engines and compatible with all commercially available engine oils. 300 ml is sufficient for 3 -- 4 litres of engine oil. Sealing first takes effect after about 600 -- 800 km.
مضاعف فاعلية البنزين Liqui Moly Speed Tec Petrol Speed
LEAK FINDER
يكشف مكان التسريب لاى سائل بالسيارة !!
is a leak testing fluid for locating leaks in gas and compressed-air systems. Leak-Finder Spray is used to find leaks in tanks, pipework, hoses, screwed connections, welded seams, flange connections and fittings. Water-soluble, biodegradable test fluid filled with environ-mentally-compatible propellant. The product’s high foam yield ensures economic and reliable use.
للحام اى كسر فى المحرك او الفتيس على البارد
Knet-Metall 50g
is a 2-component epoxy putty which bonds to all materials. Stable in the presence of salt solutions, dilute aqueous acids and dilute alkalis. Can be ground, sawn and painted over after 3 hours.
كاشف التنفيس فى المانيفولد !!
INTAKE SYSTEM LEAK DETECTOR 200ml
Intake System Leak Detector is extremely easy to use and locates leaks in the intake system within seconds. As soon as the engine speed has dropped, the leak has been located. The product has a high auto-ignition temperature and complies with the safety regu-lations. Compatible with engines and catalytic converters.
مهما كانت لزوجة الزيت مرتفعة فى الفتيس المانيوال او فى الكرونة هذا المنتج يسمح بتسييلها ولاكن دون المساس باللزوجة المطلوبة مما يوفر فى استهلاك الوقود !!
HYPOID GEAR OIL TDL SAE 75 W-90
Multipurpose gear oil for universal use. As this is a total drive line (TDL) gear oil, it is most suitable for lubricating all drive elements, from demanding synchronised and non-synchronised manual transmissions to hypoid drive axles. Reduced friction as a result of the optimum viscosity level helps to save fuel.
Di-Electric Grease
هو عبارة عن سيلكون+شحم ممزوجين سويا بشكل خاص لعدم صداء كابلات البوجيهات والبطارية ومنع تهريب الكهرباء واحكام الشرارة للبوجيهات !!
Max Professional Di-Electric Grease protects, seals, lubricates and insulates electrical contacts, spark plugs and battery terminals.
Di-Electric Grease
Use on spark plug wires, trailer hitch
After putting the new spark plugs in, put a liberal amount of
Electric Grease
هنا محطوط على راس البوجيه !!!
هنا محطوط على كابل البوجيه نفسه !!!
Also prevents spark plugs from fusing to boots. Required for modern cars
ده منتج غير ليكى موللى لانى مالقيتش صورته !!!
Generally, dielectric grease is used in any situation
  #65
قديم 25-09-2011, 06:33 PM
اجمل تعليق على اول عبوه للاسف liqui moli لاتصنع البيرة ايضا بل تصنع افضل معالاجات كيميائية للسيارات معتمدة على وجه كوكبنا
CARS ADMIRE باشا من كثرة منتجات الشركة انا اشك ان صاحب المصنع الالمانى حافظ منتجاته ولكن سيادتك بتغطس فين وتجيب المعلومات كلها انا اشتريت الزيت وال INJECTION CLEANER وحاجة اسمها OCTAN BOOSTER وقلت كفاية ولكن تخيل احد الاعضاء عندما عرف ان ماركة LIQUI MOLI اتخلق لها وكيل فى مصر اشترى الزيت وعدد معظم المنتجات التى ذكرتها سيادتك واشتراها وقال انه كان يستوردها
DR Elmanahry
موضوع مغلق
ليكوى مولى, liqui moly, زيت, زيت محرك, زيت الموتور, زيت فتيس, زيوت السيارات, زيوت زادو, زيوت سيارات, revitalizant, xado
الساعة الآن 03:54 AM.
