-   رينو كليو Clio (https://www.masrmotors.com/vb/forumdisplay.php?f=163)
-   -   رينو كليو-3 الجديدة (https://www.masrmotors.com/vb/showthread.php?t=9205)
د0تامر محمد 06-06-2009 01:42 AM
رينو كليو-3 الجديدة
جديد:رينو كليو-3 الجديدة
http://dzautos.com/images/2136.jpg
http://dzautos.com/images/2138.jpg
http://dzautos.com/images/2140.jpg
http://dzautos.com/images/2137.jpg
http://dzautos.com/images/2139.jpg
http://dzautos.com/images/2141.jpg
http://www.renault.com.au/images/car.../home/home.jpg
http://www.renault.com.au/images/car.../images/04.jpg
http://www.renault.com.au/images/car.../images/03.jpg
د0تامر محمد 06-06-2009 01:52 AM
رد: رينو كليو-3 الجديدة
engine
Type Euro 4
Capacity (cc) 1,998
Bore x stroke (mm) 82.7 x 93
Number of cylinders/valves 4 in-line/16
Compression ratio 11.5:1
Max. power (kW) 145
Max. power (rpm) 7,250
Max. torque (Nm) 215
Max. torque (rpm) 5,550
Injection Multipoint
Fuel Premium unleaded (98 RON rec.)
tRanSMiSSion
Type 6-speed Manual
Speeds at 1000rpm in 1st gear 8.33
2nd gear 13.62
3rd gear 17.88
4th gear 21.99
5th gear 27.36
6th gear 32.77
SteeRing
Type Variable Electric Power Assist
Turning circle between kerbs/
walls (m)
11/11.40
Turns lock-to-lock 2.83
SuSpenSion
Front suspension Double-axis strut system
Rear suspension
Torsion beam with programmed
deflection – coil springs
Front/rear anti-roll bar - dia (mm) 20/30 integrated
eMax. speed (kmph) 223
0 to 100km/h 6.9
Fuel ConSuMption^
City (L/100km) 11.6
Highway (L/100km) 6.5
Combined cycle (L/100km) 8.4
CO2 Emissions (g/km) Euro4 199
CapaCity
Fuel tank (litres) 55
WeigHtS
Kerb weight (kg) 1,221
mohamed ibiza 06-06-2009 02:14 AM
جامده جدا يا دكتور:)
الساعة الآن 05:08 AM.
