2011 Kia Cadenza bows in Korea, replacing Amanti in the U.S.
http://www.blogcdn.com/www.autoblog....enza-630op.jpg Kia has taken the wraps off the 2010 Cadenza in its home market before its official debut at next month's Riyadh Motor Show in Saudi Arabia, and if you're wondering what the South Korean automaker had planned for the next generation Amanti, this is it. Based on an all-new front-drive platform (Type-N) spanning 195.5 inches, the Cadenza is slightly shorter than the Amanti it's due to replace, but its wheelbase has grown to 112 inches and Kia managed to reduce the weight by over 280 pounds while keeping torsional rigidity and overall strength up. MacPherson struts are employed up front with a multi-link suspension in the rear, while 11.8-inch discs (front) and 11.2-inch rotors (rear) are hidden behind standard 16-inch or optional 17-inch wheels. Three engines, each mated to a six-speed automatic transmission, will be available when the Cadenza launches outside of North America in January. Outputs will range from 162 (four-cylinder) to 286 hp (V6), with the latter like to come to the US. Kia hasn't released when the new Amanti will make it Stateside, but the smart money says sometime late in 2010. Make the jump for the full release. |
الساعة الآن 09:33 PM. |
