Renault Twizy Price
http://www.zercustoms.com/news/image...lt-Twizy-1.jpg Renault announced at the end of last week the price of the Twizy for the European market. The Renault Twizy will be available in two versions, the base version, with a 17 hp motor, and the Twizy 45 which has a 5 hp motor. The advantage of Renault's Twizy 45 is that in some countries, it doesn't require a driving license. The Renault Twizy is much safer than a two-wheel vehicle, offers 50 liters of luggage space, thanks to a semi-rigid all-purpose bag, and offers extra protection against bad weather and the cold. Renault will equip the Twizy with Parrot audio kit featuring Bluetooth connectivity and rear parking sensors. Full specifications of the Renault Twizy are available lower down this page. The Renault Twizy price list starts at 6,990 EUR for the Twizy 45, which comes with a 45 EUR per month lease of the battery. The base Renault Twizy will be available in two trim levels, Urban, priced from 7,690 EUR with EUR 49/month for the battery and Technic, which will cost you 8,490 EUR and the same amount for leasing the battery. Renault Twizy Specifications: DIMENSIONS Standard wheels 13 inches Length 2,337mm Width, not including mirrors 1,191mm Height 1,461mm Wheelbase 1,684mm Front/rear track 1,050mm/1,036mm Front/rear overhang 292mm/345mm Kerb weight 450kg, including battery (100kg) Standard tyres 125x80 R13 (front) / 145x80 R13 (rear) MOTOR Type Electric Transmission Direct, with reducer and forward/reverse inverter Maximum continuous power (EEC) 4kW (5hp) / 8kW (10hp) 45kph version / 80kph version Maximum peak power (EEC) 7kW (9hp) / 13kW (17hp) 45kph version / 80kph version Maximum torque (EEC) 57Nm BATTERY Type Lithium-ion Standard cycle range 100km PERFORMANCE Top speed 45kph / 80kph 45kph version / 80kph version |
الساعة الآن 05:02 PM. |
