-   ميكانيكا السيارة (https://www.masrmotors.com/vb/forumdisplay.php?f=148)
-   -   Automatic clutch system for MANUAL GEAR BOX car (https://www.masrmotors.com/vb/showthread.php?t=42171)
cars admire 08-12-2010 01:22 AM
City clutch™ is a product which is very useful in converting your manual transmission vehicle into semi automatic one. Its an automatic clutch operating system which uses the existing clutch pedal mechanism system. No modification is made to the original clutch pedal mechanism system in your vehicle. By adding this system you can change gear without operating the Clutch pedal with your foot.
The clutch operation completely becomes an automatic according to the vehicle start, stop and speed. You only have to operate the accelerateor and brake pedals in combination with your gear selector.
How It Works
The complete unit comprises of an actuator unit and an microprocessor based electronics controlled unit. The system is connected to the speed sensor, Battery, Brake lights, to a button on the gear shaft lever knob, the accelerator detection switch & the clutch pedal.
You will be provided with a little RED button on top of the Gear shaft knob. Every time you want to change gears, you press that red button. The Micro-processor controlled unit will detect it and send the command to motorized actuator unit. The motorized actuator unit will disengage the clutch. Now, after changing the gears, you’ll release the red button and the clutch will automatically be engaged. The speed of clutch engaging is totally depend on the vehicle speed situation All this will happen real-time, in back-ground
Features
  • Tension Free driving and Very reliable
  • Complete automatic control of clutch
  • Easier driving for a car
  • Transferable from one car to another
  • Save fuel upto 20% in traffic condition
  • Left Leg free Operations
  • Easier driving for a manual transmission car
  • You can change gear without operate the clutch pedal with your foot
  • Suitable for most vehicles
  • There is no need of any modification in your car
  • Getting better fuel economy then manual drive due to microprocessor controlled engagement of clutch
  • You can interchange manual to automatic anytime by a simple ON/OFF switch ( Multi function system)
  • Specially designed for driving a car in heavy congested city traffic.
  • Easily Transferrable from your one car to next.
  • Very useful for physical handicapped, older person & women for driving a car
What is Semi-Automatic car? » cclutch04x
http://theblackink.files.wordpress.c...h04x.jpg?w=450
The City Clutch device inside a car
INstallation of City Clutch
Welcome to City Clutch
"City Clutch" is a simple easy to install device which can convert ANY NORMAL car into a semi-automatic one (Automatic Clutch System) without modification in your Car Engine, Gear Box or disturbing the inner beauty of your car
CONTACT US at edcrajesh@gmail.com
Or call at +919825065934
Females
http://4.bp.blogspot.com/_itIoiAnZ4X...men+driver.jpg
Women unlike earlier though are now become active in car driving, influencing the market in many ways. Either you call it a need of the time or we can say the increasing participation of females in Indian economy, the Nos of FEMALE drivers are increasing fast.
Whatever may be the reason, the number of proficient female drivers is very small. Some females really find it very difficult to manage the co-ordination of three most important things while driving, as a result the car engines get stall very frequently, resulting a disappointment while driving.
As you know car driving requires a continues coordination of Clutch, Brakes & Accelerator, specially when u are driving in Heavy Traffic congestion, or driving at up hill or in initial gears.
City Clutch is a device which can gives complete freedom from the coordination of Clutch, Brake and Accelerator. After Installing the City Clutch, the Clutch of your car becomes totally Automatic, so as a drivers you only have to take care of Brakes and Accelerator. you can more concentrate on Steering, and traffic around you.
City Clutch gives Total hassle free driving for Females.
We are the manufacturer of a simple device which can convert any car into a semi-automatic one.
you can have the pleasure of clutch free driving.
NO Need of using your Left Foot at all after installing this device.
Very Useful for Physically challenged, female drivers, old age people, Traffic congestion & and for those who are looking for the joy of Automatic driving in their own car.
NO modification in Engine or Gear box. we don't even disturb the inner beauty of your car.
contact at 09825065934 or visit at www.semiautomaticar.blogspot.com.
Control your car by only brake pedal in heavy
traffic congestion and reduce physical stress
How to convert a Manual car into a Semi Automatic !!!?????under General
(A simple device can convert your Manual car into a Semi Automatic car with the installation of a simple " City Clutch Device Developed recently.the advantage of the device is as follows :-
1. No-Clutch Function
Like an automatic vehicle, start and stop can be conducted only by the accelerator and brake system without using the left foot as much as manual geared vehicles. Therefore the physical effort is reduced while driving.
2. Interchange of Manual and Automatic(Multi-Function System)
Whenever the clutch-pedal is pressed down, it changes to manual state. Hence, the manual system and automatic system are interchangeable.
3. Economic-Viability and Environmental Concern
The fuel consumption is similar to an ordinary manually geared vehicle, which means that the fuel consumption rate is 20%~30% lower than the automatic one. Therefore it is more economically viable. Along with this advantage, the air pollution due to automobile exhaustion is reduced, contributing to the environmental protection.
4. Adaptable And Transferable
The CITY CLUTCH system can be installed in any domestic or foreign vehicle and can be easily transferred from one vehicle to another, incurring only labor and minor hardware costs. Persons who are unable to accomplish the clutching function, but need to drive a manual transmission for personal or professional reasons may now consider the CITY CLUTCH system as a practical option to an automobile or even a career change. Many persons who are fully capable of using a standard clutch may also fund the CITY CLUTCH system attractive for its pure convenience, especially in stop and go traffic, and for tractor trailer and utility vehicles which are not available with automatic transmissions, CITY CLUTCH frees you from the task of clutching without a loss of "feel" or control.
5. Shift With Precision And Ease
Upon touch the gearshift lever knob, the CITY CLUTCH automatically depresses the clutch pedal. Once in gear, accelerate, and let CITY CLUTCH do the rest! Shifting gears is accomplished in a standard manner, in the style that you are accustomed to, only without the need to operate the clutch.
6. Target Vehicles
Installation is possible in all kinds of manual-geared vehicle, (cars, jeeps, trucks, buses, etc.)
if u want more information u can mail me at edcrajesh@gmail.com or visit my blog at http://semiautomaticar.blogspot. com/
for more information read my review on this product on mouthshut
<A href="http://www.mouthshut.com/review/Tips_on_Modifications_and _Enhancement_in_Cars-148234-1.html">http://www.mouthshut.com/review/Tips_on_Modifications_and _Enhancement_in_Cars-148234-1.html
lovelyemily 15-01-2011 12:48 AM
رد: Automatic clutch system for MANUAL GEAR BOX car
dear sir
i want to ask is this clutch applicable to my car, fiat (ritmo) 1982?
and if yes how much it cost? keeping in mind that i live in egypt.
thanks a lot in advance
cars admire 27-01-2011 04:08 PM
المشاركة الأصلية كتبت بواسطة lovelyemily (المشاركة 335439)
dear sir
yes
can fit with any kind of manual cars
of sure
but i am so sorry because i am here in egypt too
for that i can not tell you
how much cost
it can
make for you
karem ali 27-01-2011 04:14 PM
Thank you
GIFT4UGIFT4UGIFT4U
cars admire 27-01-2011 04:37 PM
المشاركة الأصلية كتبت بواسطة karem ali (المشاركة 348208)
Thank you
GIFT4UGIFT4UGIFT4U
karem ali
:fun_36_3_3[1]:
الساعة الآن 07:39 AM.
