وداعا لمشاكل انقطاع الماء !!billboard drinkable water
5 مرفق
Drinking water from air humidity
Munters PotableAire is a humidity control system that uses new technology to capture water during the dehumidification process and purify it into drinking water. companies are creating water makers that convert air into drinking water, sometimes with technology similar to a dehumidifier. High Efficient Air & Water Cooled Ice Maker Watermill literally sucks up the air's humidity and eventually converts it to drinking water. It performs its own filtering and purification by exposing ... رابط الصفحة إخطار إعادة التوجيه The humidity is extracted from the air, condensed and collected :CHUBBY~36: This machine makes drinking water from air atmospheric water generator Thailand Go Beyon Green Technology. Pure Drinking Water From 15 to 5000Liters Per Day From The Air We Breathe. http://www.youtube.com/playlist?list=PL304532671FA11E53 Amazing revolution! Water from the air machine (WFA) - YouTube Ecoloblue 30 Atmospheric Water Generator - YouTube :0369B3~177: رابط الصفحة 10W 50Hz 400mg H Air Water Purifier Ozone Generator Function Machine Sterilizer | eBay the DewPointe DH9 Atmospheric Water Purification System extracts water vapor from the air and converts it to pure drinking water. The system uses similar technology as some home dehumidifiers to pull the moisture from the air. By pulling moisture out of the atmosphere, the DH9 is said to eliminate virtually all contaminants that might otherwise occur in groundwater. The device then further purifies the water to eliminate 99.99% of contaminants. There’s an electrostatic air filter to remove small airborne particles like pollen and dust, a germicidal uV light that destroys bacteria and other microorganisms, a coconut hull filter that eliminates heavy metals, chlorine residuals and mineral salts, and a reverse osmosis (RO) filter to remove any remaining pathogens or fine particles. Unlike other RO filters, where the wastewater is then flushed (so that the user drinks one purified gallon for each six to ten that are wasted), the DH9’s revolutionary RO filter reprocesses it so that no water is lost. A gravity-fed storage tank holds 6.5 gallons that would be accessible even in the event of a power outage. Too good |
رد: وداعا لمشاكل انقطاع الماء !!billboard drinkable water
ahmed_eng2001
:fun_36_3_16[1]: |
روعه روعه روعه :balloons71:,,, عالم بتفكر و بالنسبه لنا كمصريين افضل مليون مره من مياهنا الملوثه سبب امراضنا و افضل كمان من الفلاتر الباهظه الثمن و في الاخر لا تنقي المياه من الجراثيم المسببه للامراض ...
بس سؤال هي كدا زي التكييف .؟. و هل بتؤدي دوره في الصيف لانها بتشد الرطوبه فبتلطف الجو:thnkr: .؟!. |
مكثف للرطوبة من الهواء وتحويله لماء شرب اتفرج على الفيديوهات المرفقة مع الموضوع الاءصلى :pod_of_gold::pod_of_gold ::pod_of_gold::pod_of_gol d: |
تجربة ألة تحول رطوبة الهواء إلي ماء صالح للشراب
‫طھط¬ط±ط¨ط© ط£ظ„ط© طھط*ظˆظ„ ط±ط·ظˆط¨ط© ط§ظ„ظ‡ظˆط§ط، ط¥ظ„ظٹ ظ…ط§ط، طµط§ظ„ط* ظ„ظ„ط´ط±ط§ط¨â€¬â€ژ - YouTube ‫ط§ظ„ظ…ط®طھط±ط¹ ط®ط§ظ„ط¯ ظ…طµط·ظپظ‰ ظپظ‰ ط¹ط² ط§ظ„ط´ط¨ط§ط¨ ظˆط§ط¨طھظƒط§ط± ط¬ظ‡ط§ط² ط§ظ†طھط§ط¬ ط§ظ„ظ…ط§ط، ظ…ظ† ط§ظ„ظ‡ظˆط§ط،‬â€ژ - YouTube FLASHCar |
الساعة الآن 04:21 AM. |
