-   فولكس (https://www.masrmotors.com/vb/forumdisplay.php?f=15)
-   -   vw old beetles + hho (https://www.masrmotors.com/vb/showthread.php?t=101352)
cars admire 31-10-2012 07:00 PM
http://DiscoverHydrogen.com for details. HHO Generator MPG Test - Gas Mileage Test Results Hydrogen Generator Kit.
Get step-by-step instructions how to Convert Your Vehicle into a Hydrogen Hybrid and SAVE TONS OF MONEY on fuel costs.
Hydrogen Hybrid Conversion Plans show you how to build and install your own Hydrogen Generator System (HHO Generator), which produces Hydrogen "On-Demand", as you need it.
This technology has proven to increase gas mileage by as much as 150% on both gasoline and diesel engine vehicles.
Check www.DiscoverHydrogen.com for details.
If you want to learn ways hho generator mpg test then youve found the best tips, tricks, secrets and techniques. By converting your car into a hydrogen hybrid you get hho generator mpg test and also reduce exhaust gas emissions. To build and install an HHO Gas saver kit is the most effective way hho generator mpg test and improve horsepower and engine performance. This kind of invention can be made at home and installed in your car to hho generator mpg test without upgrades or engine modification.
This is the best method and technique available for hho generator mpg test. This device or invention for hho generator mpg test is not a scam and does work. HHO gas injection really works to hho generator mpg test. None of the devices for hho generator mpg test work as good as a Hydrogen Generator Fuel Cell Kit to save fuel and increase gas mileage in gasoline and diesel engine vehicles. Learn how to build and install your own hho generator kit in your car or truck and hho generator mpg test by as much as 150% or even more!
Many people wonder does an Hydrogen Generator really works to "hho generator mpg test" but with the right car parts, instructions and plans you can build a good hho generator. There are tons of a few secret tricks and tip you can install to hho generator mpg test in internal combustion engines with fuel injection or carburetors. HHO is the best idea for hho generator mpg test and are cheap to save money on gas prices. Hydrogen fuel saving kits are proven effective for hho generator mpg test gas savings for gasoline and diesel engines. It is the best method and technique to hho generator mpg test in both city and highway driving without hypermiling.
http://2.bp.blogspot.com/_pA_SRrP57Y...171350_std.jpg
So get the best Homemade fuel saver device plans and build and install your own Hydrogen conversion kit in your car or truck to hho generator mpg test. A home made gas saver will save fuel and reduce hydrocarbon emissions. It's the best hho generator mpg test that you can build or make DIY do it yourself for automobiles to save gas money. You can also use a K&N air filter, another fuel saver device, a cold air intake or high-flow muffler or those MPG pills or a gas mileage computer chip. Then you can save money and fight high gas prices to hho generator mpg test using the best advice and technology.
http://www.youtube.com/watch?v=CUh2YZGL19g
Best resources for hho generator mpg test online.
http://www.youtube.com/watch?v=ECKgzQxa1P4
How To Save Money on Gas
http://www.wikihow.com/Save-Money-on-Gas
Increase Gas Mileage
http://www.ftc.gov/bcp/edu/pubs/consumer/alerts/alt064.shtm
Hydrogen Electrolyzer Kit - Increase Gas Mileage & Save Gas
http://www.youtube.com/watch?v=1awUAvpjIPw
http://www.youtube.com/watch?v=w-jUfOjTa3M
http://www.youtube.com/watch?v=avt4pTvnt-E
http://www.youtube.com/watch?v=AffihxhBN_c
http://www.youtube.com/watch?v=PBnDHoRmSxY
mhamdy75 31-10-2012 07:10 PM
رد: vw old beetles + hho
:Wkiss5::Wkiss5::Wkiss5:
cars admire 31-10-2012 08:01 PM
المشاركة الأصلية كتبت بواسطة mhamdy75 (المشاركة 788274)
:GROWIN~12::GROWIN~12::GR OWIN~12::GROWIN~12::GROWI N~12::GROWIN~12:
روبرت مجدي 01-11-2012 10:51 AM
thanks :THUMB_~112:
but how i can make that in my car in egypt:shy:
cars admire 01-11-2012 05:31 PM
العنوان: 3ش الحمام خلف العبودي - روكسي - مصر الجديدة - القاهرة01098320031
المشاركة الأصلية كتبت بواسطة روبرت مجدي (المشاركة 788613)
thanks :THUMB_~112:
1800 جنيه بالتركيب !!!!!!!!وضمان سنة !
شغل عربيتك بمياه و بنزين او سولار ومياه.عملية التركيب بسيطة.سهلة التركيب - سهلة الازالة.
تشتغل علي 99.9% من جميع السيارات.
قلل تكاليف البنزين او السولار الخاص بك الي النصف.
يعمل في العالم وبنسبة 100 ٪ آمنة وقانونية.
البنزين كفائته اكثر 50% و تنتج انبعاثات انظف.
لا تؤثر علي سحب السيارة.وكزلك الديزل
.يوجد ضمان عند الشراء
Change your car system with simplified process and save over 50% of fuel
Only 1500 + guarantee for 1 year + taxes + installation ( Total 1800 )
غير نظام عربيتك بعملية مبسطة و وفر اكتر من 50% من البنزين او السولار
فقط 1500 جنيه + 300 تركيب
http://www.masrmotors.com/vb/images/icons/b9.gif
For more info: 01118111888 - 01114270842 - 01098320031
الرابط
https://www.facebook.com/pages/%D9%8...409793?sk=info
:pod_of_gold::pod_of_gold ::pod_of_gold::pod_of_gol d::pod_of_gold::pod_of_go ld::pod_of_gold:
الساعة الآن 07:58 AM.
