رد: حد ممكن يقيدنا الموضوع ده نصب ولا بجد.؟؟؟؟!!!!
:fun_36_3_9[1]::fun_36_3_9[1]::fun_36_3_9[1]::fun_36_3_9[1]::fun_36_3_9[1]::fun_36_3_9[1]::fun_36_3_9[1]::fun_36_3_9[1]::fun_36_3_9[1]:
Converting A Car To Run on Water - Cars Burning Hydrogen: حد ممكن يقيدنا الموضوع ده نصب ولا بجد.؟؟؟؟!!!!
<TABLE class=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center><TBODY><TR vAlign=top><TD class=alt1>DR/nktis
http://www.youtube.com/watch?v=z2aaFHucYsA http://www.youtube.com/watch?v=Arn1xlsF6GA new system is that it uses the company's membrane electrode assembly (MEA), which contains a material capable of breaking down water into hydrogen and oxygen through a chemical reaction As per the claims it runs only on a 300W "Water Energy System (WES)" where WATER is the only FUEL. Any water will do, salt, swamp, pond and tea! >>>>>>>>>>>>>>> regarding the vacuum valve sensor. The vacuum valve sensor must not get any water inside where the diaphragm is operating or it will keep it in the on position. The diaphragm is a very sensitive rubber piece and water between the case and the diaphragm will keep it in a on position. It is recommended to put it in a enclosed container watertight. I found this out when I had the device setting on the outside of the car testing it and I decided to wash the inside of the engine area with the car in the off position and seen it working still. This vacuum valve was designed for a furnace in a dry environment and I recommend for everyone using one keep it dry. http://www.youtube.com/watch?v=of2XWkj49RQ http://www.youtube.com/watch?v=0YlhZyUPxLo ديزل http://www.youtube.com/watch?v=FYuwY_PSmgg http://www.youtube.com/watch?v=omjPrRfeBMU </TD></TR></TBODY></TABLE> :GROWIN~12::GROWIN~12::GR OWIN~12::GROWIN~12::GROWI N~12::GROWIN~12::GROWIN~1 2: |
بس فكره المياه كوقود في الجون علي الاقل هتوفرلي ال72 جنيه بنزين الشهر:fun_36_1_7[1]: ويا ريت لو تشفولنا حل بديل للزيت عشان مش عايز اصرف.......ههههههههههه:RO FL_C~118::ROFL_C~118: |
الساعة الآن 05:17 PM. |
